Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Activating Task Flows for Siebel LoyaltyMany features of Siebel Loyalty are driven by Siebel task flows. You can modify these task flows to change the behavior of the product. Before using Siebel Loyalty, you must first publish these task flows. Once the task flows are published, then you must activate the task flows. Activating these task flows makes these features available in the employee application. Task flows are not supported in the partner application and the member application (eLoyalty). For information about publishing and activating task flows, see Siebel Business Process Framework: Task UI Guide. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
