Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Defining Lists of Values for Siebel Loyalty >
Defining Loyalty Membership Card Types
Before you define the tiers for specific loyalty programs, you must define membership card types, so you can select the appropriate membership card type for each tier. Typical values are Platinum, Gold, and Silver membership cards, which would be selected for the Platinum, Gold, and Silver tiers.
To define membership card types
  1. Navigate to the Administration - Data screen, List of Values view.
  2. For each membership card type, add a new record to the List of Values list, and complete the necessary fields, as described in the following table.
    Field
    Description
    Type
    Enter LOY_MEMBER_CARD_TYPE.
    Display Value
    Enter the name of the card type. This name is displayed in the list of values for this membership card type.
    Language-Independent Code
    Enter the Language Independent Code for the card type.
    Language Name
    Enter the language that the display value is displayed in.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
