Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty >
Creating the Loyalty Host Company as a Partner
You must create a record representing the Loyalty host company in Partner Administration view. All companies using Loyalty must be registered as partners with the type Loyalty Partner, including the host company as well as the partner companies. To create the host company as a partner
- Navigate to Administration - Partner screen, Qualified Partners view.
- In the Partners list, add a new record, and complete the necessary fields. Some fields are described in the following table.
Name |
Enter the name of the host organization (your company). |
Partner Type |
Select Loyalty Partner. |
- Click Register.
- In the Register Partner dialog box, select the Organization check box and click Save.
