Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Configuring Siebel Loyalty > Allowing Manual Processing of Queued TransactionsSome transactions are created with the status of Acceptable, which means that they are processed when the user clicks the Process button. Some transactions are created with the status of Queued, which means that they are processed in batch mode by the Siebel Loyalty Engine. For example, when a member creates a redemption order on the Loyalty eMember Web site, the redemption transaction that it creates to debit the points has a status of Queued, so it cannot be processed manually by clicking the Process button. The status that the transaction has when it is created depends on the user property OrderToTxn: Transaction Status, which you can modify in Siebel Tools. For more information about Siebel Tools, see Using Siebel Tools. To allow manual processing of transactions
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
