Siebel Loyalty Administration Guide > Working with Siebel Loyalty Program Members > About Working with Loyalty Members Using the Siebel Application Interface >
Restricting Loyalty Point Purchases
The purchase of points could have certain limitations, which could differ from member to member based on each member's Dominant Tier and membership type. For example, a Platinum Tier member might be able to purchase more points in a single transaction (Transaction limits) or even over a period of time (Period Limits), as compared to a Bronze member. To restrict point purchases
- Navigate to the Loyalty Program Administration screen.
- Locate the program and click its Program Id hyperlink.
- Click the Point Purchase Setup tab.
- Add a new record to the Point Purchase Setup list, and complete the necessary fields. Some fields are described in the following table.
Point Type |
Select Point Type. |
Membership Type |
Select the Membership Type. Choices include:
- Account
- Household
- Individual
- Partner
Tier |
Enter the Tier. |
Minimum Transaction Quantity |
Enter the Minimum Transaction Quantity. |
Maximum Transaction Quantity |
Enter the Maximum Transaction Quantity. |
Purchase Period Limit |
Enter the total number of points a user can purchase in a given period of time. This can be based on the Purchase Start Date attribute at the program level. |
