Siebel Loyalty Administration Guide > Working with Siebel Loyalty Program Members > Bulk Loyalty Membership Administration >
Administering Bulk Accruals
If you import transactions into Siebel Loyalty, then they do not go through the usual transaction validations. Therefore, you must administer bulk accruals as follows:
  • First import all the transactions into the staging table.
  • Schedule the LOY Bulk Import Accrual process workflow to run as a background process.
  • The workflow validates the transactions. The status of transactions that pass the validation remain as In Progress. The status of transactions that do not pass the validation are set to Failed.
  • All the transactions that passed the validation can be imported into the EIM transaction table. From there, they are imported to loyalty tables.
  • All the failed transactions can be sent to the appropriate partners for validation.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
