Siebel Loyalty Administration Guide > Using Siebel Loyalty with Partners > Sending Transactions to Partners for ReviewSome transactions need to be reviewed and approved by partners. For example, the host company might send transactions to a partner for approval if the companies are running a type of joint promotion that requires the partner's explicit approval of transactions, or a transaction might be rejected by the Loyalty Engine so the partner must edit the transaction's information before submitting it for reprocessing. When you create these transactions, you must select the partner employee who must review it in the Submit To field. The partner can receive the transaction for review in two ways:
To submit a transaction to a partner for review
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
