Siebel Loyalty Administration Guide > Using Siebel Loyalty with Partners > Setting Up Loyalty Terms for Precalculated Accruals > Setting Up Precalculated AccrualsPrecalculated accrual lets you set up a limit on the points that a partner can send in a single transaction in a defined time period. For example, points that can be credited directly to the member's account, without further validation by the host organization. Loyalty terms validation skip flag enables you to prevent further validation. You must specify a date range and point limit for each point type that can be precalculated. To set up precalculated accruals
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
