Siebel Loyalty Administration Guide > Using Siebel Loyalty with Partners > About Selling Loyalty Points to Partners > Selling Points to Prepaid PartnersFor prepaid partners, you begin by making the point block available for purchase. After the partner has purchased a point block, you activate it so the partner can use it. Before you sell the points to prepaid partners, you must create the point blocks, as described in Creating Point Blocks for Loyalty Programs. You also have the option of setting up auto-creation of point blocks, as described in Setting Up Auto-Creation of Point Blocks. Making the Points Available to PurchaseFor prepaid partners, you begin by making the points available to purchase. NOTE: You can also make points available for partners to purchase in the Loyalty Program Administration screen, Points Blocks view. Point blocks are point type independent. To make points available for partners to purchase
Activating the Point Block for Prepaid PartnersAfter a prepaid partner has purchased the point block, you activate it so it is available for the partner to use. To activate points so they can be used by prepaid partners
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
