Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Programs > Process of Setting Up Loyalty Programs > Defining Point Gift SetupYou can allow active members of a program to give points as gifts to other active members of the same program. You restrict the number of points that can be given or received to prevent members from abusing this feature. For example, if a platinum member can buy points at a 10% discount, then you might want to restrict platinum members so they can give only a limited amount of points, so they do not give too many discounted points to members in other tiers. You must enter limits on both the giver and the recipient of a specific point type, membership type and tier for gift points to be enabled for that combination of point type, membership type, and tier. Alternatively, you might want to restrict members in other tiers so they can receive only a limited number of points from platinum members. In addition to the steps defined here, you must create a point gift product, set a price for this product, and associate the product with the program. For more information, see Setting Prices for Member Services.
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
