Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Programs > About Loyalty Program Points, Tiers, and RewardsLoyalty programs give members points for purchases or for other behavior. Members benefit from earning points in these ways:
Redeeming Points for RewardsMembers can redeem these points for rewards, such as products. For example, a program can give members frequent flyer miles that they can redeem for airplane flights. When you define products, you specify how many points members can earn by purchasing the products. You also define how many points the members must redeem to purchase the product. NOTE: You can define products for accrual without specifying points. For example, you can create a generic product, such as Flight, to denote any flight activity. You can then use promotions to allocate points based on the member's transactions with the host company. Qualifying for Tier StatusMembers can also qualify for tier statuses, such as Silver Member, Gold Member, or Platinum Member, by earning a specified number of qualifying points in a specified time. Most loyalty programs give members two types of points:
Members can only redeem their nonqualifying points. Using Points to Pay for Some Member ServicesYou can set up some member services, such as giving gift points and reactivating points, so members can pay for them using cash, points, or a combination of cash or points. For more information, see Setting Prices for Member Services. Expiration of PointsPoints that are given to members might or might not have an expiration date depending on the expiration level defined. The point expiration basis is set at the program level and can be defined at these levels:
A point's expiration date is usually maintained at the point level, except expiration for dates based on member activity. However, if the expiration level value defined at the program level is set to Tier Level and Expire Points check box is not selected for a tier, then points do not expire for any member who is part of that tier, even if the points are past their expiration date. The points keep their original expiration date, but they do not expire until the member becomes part of a tier that expires points. If an accrual transaction is canceled, then the points that were given are returned to the original point block. If a point expires, then it is not added back to the point block. An expired point can no longer be used, just as if the member had used it for a redemption award. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
