Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Programs >
Example of Setting Up Retroactive Tier Changes
Setting up a retroactive tier program requires adding additional program level attributes, defining additional tier rules, and adding an additional Admin - Retro Accrual promotion. These configurations determine whether or not retroactive changes are applied to transactions.
Creating Retroactive Tier Member Attributes
The tier class qualifying period member attributes are used to specify the current and previous qualifying period of a member for a particular tier class. These attributes determine whether or not retroactive tier logic must apply to a transaction.
Every tier class that is eligible for retroactive tier changes needs the following three member attributes defined:
  • TC1 Previous QP Start. For tier class 1, this attribute is the start date of the previous qualifying period.
  • TC1 Current QP Start. For tier class 1, this attribute is the start date of the current qualifying period.
  • TC1 Current QP End. For tier class 1, this attribute is the end date of the current qualifying period.
To create retroactive tier member attributes
  1. Navigate to the Loyalty Program Administration screen.
  2. Locate the program that the attribute applies to and click its Program Id hyperlink.
  3. Clear the program form's Active check box.
  4. Click the Program Level Attributes view tab.
  5. In the link bar of the Program Level Attributes view, click Member Attributes.
  6. Add the first record to the Program Level Attributes list, and complete the necessary fields. Some fields are described in the following table.
    Field
    Value
    Name
    Data Type
    Date
    Display to User
    No
  7. Add the second record to the Program Level Attributes list, and complete the necessary fields. Some fields are described in the following table.
    Field
    Value
    Name
    Data Type
    Date
    Display to User
    No
  8. Add the third record to the Program Level Attributes list, and complete the necessary fields. Some fields are described in the following table.
    Field
    Value
    Name
    TC1 Current QP End
    Data Type
    Date
    Display to User
    No
  9. Repeat the steps in this procedure to add these attributes to each tier class and select the Active check box to activate the attributes.
  10. When you are finished creating all attributes for the program, select the program form's Active check box to activate the program.
Creating Retroactive Tier Member Tier Attributes
These attributes are used to distinguish a retroactive tier change from a regular tier change.
To create retroactive tier member tier attributes
  5. In the link bar of the Program Level Attributes view, click Member Tier Attributes.
  6. Add a record to the Program Level Attributes list, and complete the necessary fields. Some fields are described in the following table.
    Field
    Value
    Name
    Tier Approval Status
    Field
    Read Only
    Y
    Data Type
    String
    Pick List
    LOY Member Tier Approval Status Picklist
  7. Add another record to the Program Level Attributes list, and complete the necessary fields. Some fields are described in the following table.
    Field
    Value
    Name
    Transaction Sub Type LIC
    Field
    Read Only
    Y
    Data Type
    String
  8. When you are finished creating all attributes for the program, select the Active check box to activate the attributes and then select the program form's Active check box to activate the program.
Creating Retroactive Tier Transaction Attributes
These attributes are used to identify the date of the transaction, the current date in Siebel Loyalty, the age of the transaction and determines whether or not any retroactive tier action must be taken.
To create retroactive tier transaction attributes
  5. In the link bar of the Program Level Attributes view, click Transaction Attributes.
    Field
    Value
    Name
    Transaction Age
    Field
    Transaction Age
    Read Only
    Select the Read Only check box
    Data Type
    Number
    Field
    Value
    Name
    Is Qualifying
    Field
    Qualifying Flag
    Read Only
    Data Type
    String
  8. Add another record to the Program Level Attributes list, and complete the necessary fields. Some fields are described in the following table.
    Field
    Value
    Name
    Current Date
    Field
    Current Date
    Read Only
    Data Type
    Date
  9. Add another record to the Program Level Attributes list, and complete the necessary fields. Some fields are described in the following table.
    Field
    Value
    Name
    Transaction Date
    Field
    Transaction Date
    Read Only
    Y
    Data Type
    Date
  10. When you are finished creating all attributes for the program, select the Active check box to activate the attributes and then select the program form's Active check box to activate the program.
Setting Up Retroactive Tier Rules
The retroactive tier logic requires additional rules to evaluate member records and determine if a tier change is necessary.
For the given example for the Base Tier, the following would be the new sequence of rules (assuming only points as the criterion for Tier qualification):
  1. Manual Tier Approval
  2. Retro Tier Automatic Activation
  3. 250,000 Points, Upgrade Platinum Retro
  4. 250,000 Points & Not Expired - Upgrade to Platinum
  5. 120,000 Points, Upgrade Gold Retro
  6. 120,000 Points & Not Expired - Upgrade to Gold
  7. 60,000 Points, Upgrade Silver Retro
  8. 60,000 Points & Not Expired - Upgrade to Silver
  9. Expired Cancellation Retro
  10. Base Expired, Qualify Base
  11. Manual Upgrade to Silver
  12. Manual Upgrade to Gold
  13. Manual Upgrade to Platinum
  14. Manual Qualify Base
The additional rules having sequence numbers 1, 2, 3, 9 and the modified rule with sequence number 10 are explained in the procedure below.
To set up retroactive tier rules
  2. In the Loyalty Programs list, select the program that the tiers are used by and click its Program Id hyperlink.
  3. Click the Tier Classes view tab.
  4. Select the tier class to be modified.
  5. In the Tiers view, click the Tier Id hyperlink.
  6. Click Modify.
  7. Create a new rule for this Tier:
    1. In the Rules list, add a new record and enter the values in the following table.
      Field
      Value
      Sequence
      1
      Name
      Apply To
      Tiers
    2. Click the Rule Name.
    3. To create the first criterion, add a new record in the Criteria list, and complete the necessary fields in the Criteria list and the Compare to Values Details, and Values forms, as shown in the following table.
      Field
      Value
      Sequence
      1
      Name
      Check Tier Approval
      Type of Comparison
      Compare to Values
      Object
      Member Tier
      Attribute
      Condition
      Equals
      Value
      Pending
      Value
      Pending RT Decision
    4. Click the Actions view tab and add a new record in the Actions list, and complete the necessary fields in the Actions list and form, as shown in the following table.
      Field
      Value
      Sequence
      1
      Name
      Qualify Tier
      Type
      Qualify Tier
    5. Add a new record in the Actions list, and complete the necessary fields in the Actions list and form, as shown in the following table.
      Field
      Value
      Sequence
      2
      Name
      CreateQualPeriodAttributes
      Type
      Invoke Custom Action
      Method
  8. Create the second rule for this Tier.
      Field
      Value
      Sequence
      2
      Name
      Apply to
      Tiers
      Field
      Value
      Sequence
      1
      Name
      Check Tier Approval
      Type of Comparison
      Compare to Value
      Object
      Member Tier
      Attribute
      Condition
      Equals
      Value
      RTCINT - To Be Activated
      Field
      Value
      Sequence
      1
      Name
      Qualify Tier
      Type
      Qualify Tier
  9. Create the third rule for this Tier.
      NOTE:  The values used in this procedure are for illustration purposes only. Your values might vary depending on your configuration.
      Field
      Value
      Sequence
      3
      Name
      250,000 points - Upgrade Platinum Retro
      Apply to
      Tiers
      Field
      Value
      Sequence
      1
      Name
      Greater Than or Equal To 250,000 Regular Points
      Type of Comparison
      Compare to Values
      Object
      Member Tier
      Attribute
      Regular Points
      Condition
      Is Greater Than or Equal To
      Value
      250000
    4. To create the second criterion, add a new record in the Criteria list, and complete the necessary fields in the Criteria list and the Compare to Values Details, and Values forms, as shown in the following table.
      Field
      Value
      Sequence
      2
      Name
      Check Tier Approval Status
      Type of Comparison
      Compare to Values
      Object
      Member Tier
      Attribute
      Condition
      Equals
      Value
      Pending - RTC
      Value
      RTCINT - Automatic
    5. Click the Actions view tab and add a new record in the Actions list, and complete the necessary fields in the Actions list and form, as shown in the following table.
      Field
      Value
      Sequence
      1
      Name
      Upgrade to Platinum
      Type
      Upgrade Tier
      New Tier
      Platinum
  10. Create the fourth rule for this tier.
      Field
      Value
      Sequence
      9
      Name
      Expired - Cancellation Retro
      Apply to
      Tiers
      Field
      Value
      Sequence
      1
      Name
      Is Expired
      Type of Comparison
      Compare to Values
      Object
      Member Tier
      Attribute
      Is Expired
      Condition
      Equals
      Value
      Y
      Field
      Value
      Sequence
      2
      Name
      Check Transaction Sub Type LIC
      Type of Comparison
      Compare to Values
      Object
      Member Tier
      Attribute
      Condition
      Equals
      Value
      Cancellation
    5. To create the third criterion, add a new record in the Criteria list, and complete the necessary fields in the Criteria list and the Compare to Values Details, and Values forms, as shown in the following table.
      Field
      Value
      Sequence
      3
      Name
      Check Tier Approval
      Type of Comparison
      Compare to Values
      Object
      Member Tier
      Attribute
      Condition
      Equals
      Value
      Pending - RTC
      Value
      RTCINT - Automatic
    6. Click the Actions view tab and add a new record in the Actions list, and complete the necessary fields in the Actions list and form, as shown in the following table.
      Field
      Value
      Sequence
      1
      Name
      Qualify (Tier Name)
      Type
      Qualify Tier
  11. Create the fifth rule for this tier.
      Field
      Value
      Sequence
      10
      Name
      Tier Expired, Qualify (Tier Name)
      Apply to
      Tiers
      Field
      Value
      Sequence
      1
      Name
      Is Expired
      Type of Comparison
      Compare to Values
      Object
      Member Tier
      Attribute
      Is Expired
      Condition
      Equals
      Value
      Y
      Field
      Value
      Sequence
      2
      Name
      Type of Comparison
      Compare to Values
      Object
      Member Tier
      Attribute
      Condition
      Equals
      Value
      Automatic
      Value
      Manual - Approved
      Value
      RTC - Manual - Approved
      Field
      Value
      Sequence
      1
      Name
      Qualify (Tier Name)
      Type
      Qualify Tier
  12. If your loyalty program has different sets of tiers for different customers, then repeat the steps in this procedure until you have modified all of the sets of tiers in the program.
Creating the Admin - Retro Accruals Base Promotion
When you define a Retroactive Tier program, you must create the Admin - Retro Accruals base promotion to determine the type of retroactive tier logic that is used.
NOTE:  The rules for the Admin- Retro Accruals promotion are for illustration purposes only. Actual implementation requirements can vary. If you decide you do no want to use retroactive tier logic, then you can deactivate this base promotion.
To create the Admin - Retro Accruals base promotion
  1. Navigate to the Loyalty Promotions Administration screen.
  2. Add a new record to the Promotions list, and enter the values that are provided in the following table.
    Field
    Value
    Name
    Always Apply
    Y
    Apply To
    Accrual-Product
    Program
    Enter the name of the program.
    Partner
    Enter the partners for the program.
    Product Inclusion
    All Products
    Promotion Start
    Enter one day before today's date.
    Promotion End
    Leave this field blank, because you do not want the base promotion to expire.
  3. Click the Promotion Number (#) field's hyperlink.
  4. Click the Rules view tab.
  5. Create the first rule for this promotion:
    1. Add a new record to the Rules list, and enter the values in the following table.
      Field
      Value
      Sequence
      1
      Name
      Retro Txns 1 month ago A
      Apply To
      Transactions
    2. Click the Name field's hyperlink.
    3. Add a new record to the Criteria list, and enter the values in the following table.
      Field
      Value
      Sequence
      1
      Name
      Check Txn Points
      Type of Comparison
      Compare to Values
    4. In the Compare to Values Detail form, enter the values in the following table.
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Points
      Condition
      Is Greater Than
    5. Add a new record to the Values list and enter 0 in the Value field.
    6. Add another new record to the Criteria list, and enter the values in the following table.
      Field
      Value
      Sequence
      2
      Name
      Is Qualifying?
      Type of Comparison
      Compare to Values
    7. In the Compare to Values Detail form, enter the values in the following table.
      Field
      Value
      Object
      Transaction
      Attribute
      Is Qualifying
      Condition
      Equals
    8. Add a new record to the Values list and enter Y in the Value field.
    9. Add another new record to the Criteria list, and enter the values in the following table.
      Field
      Value
      Sequence
      3
      Name
      Transaction Age < 1 Month
      Type of Comparison
      Compare to Values
    10. In the Compare to Values Detail form, enter the values in the following table.
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Age
      Condition
      Is Less Than
    11. Add a new record to the Values list and enter 30 in the Value field.
    12. Add another new record to the Criteria list, and enter the values in the following table.
      Field
      Value
      Sequence
      4
      Name
      TC1 Previous QP Start < Txn Date
      Type of Comparison
      Compare to Object
    13. In the Compare to Object Detail form, enter the values in the following table.
      Section
      Field
      Value
      Compare this Object
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
    14. Add another new record to the Criteria list, and enter the values in the following table.
      Field
      Value
      Sequence
      5
      Name
      TC2 Previous QP Start < Txn Date
      Type of Comparison
      Compare to Object
    15. In the Compare to Object Detail form, enter the values in the following table.
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
    16. Add another new record to the Criteria list, and enter the values in the following table.
      Field
      Value
      Sequence
      6
      Name
      TC1 Current QP End, Txn Date
      Type of Comparison
      Compare to Object
    17. In the Compare to Object Detail form, enter the values in the following table.
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      TC1 Current QP End
      Compare this object
      Condition
      Is Greater Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
    18. Add another new record to the Criteria list, and enter the values in the following table.
      Field
      Value
      Sequence
      7
      Name
      TC1 Current QP End < Today
      Type of Comparison
      Compare to Object
    19. In the Compare to Object Detail form, enter the values in the following table.
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      TC1 Current QP End
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Current Date
    20. Click the Actions view tab.
    21. Add a new record to the Actions list, and enter the values in the following table.
      Field
      Value
      Sequence
      1
      Name
      RTC Automatic
      Type
      RTC Automatic
  6. Create the second rule for this promotion:
      Field
      Value
      Sequence
      2
      Name
      Retro Txns 1 Month Ago B
      Apply To
      Transactions
      Field
      Value
      Sequence
      1
      Name
      Check Txn Points
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Points
      Condition
      Is Greater Than
      Field
      Value
      Sequence
      2
      Name
      Is Qualifying?
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Is Qualifying
      Condition
      Equals
      Field
      Value
      Sequence
      3
      Name
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Age
      Condition
      Is Less Than
      Field
      Value
      Sequence
      4
      Name
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      5
      Name
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      6
      Name
      TC2 Current QP End, Txn Date
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      TC2 Current QP End
      Compare this object
      Condition
      Is Greater Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      7
      Name
      TC2 Current QP End < Today
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      TC2 Current QP End
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Current Date
      Field
      Value
      Sequence
      1
      Name
      RTC Automatic
      Type
      RTC Automatic
  7. Create the third rule for this promotion:
      Field
      Value
      Sequence
      3
      Name
      Retro Txns 1 month ago C
      Apply To
      Transactions
      Field
      Value
      Sequence
      1
      Name
      Check Txn Points
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Points
      Condition
      Is Greater Than
      Field
      Value
      Sequence
      2
      Name
      Is Qualifying?
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Is Qualifying
      Condition
      Equals
      Field
      Value
      Sequence
      3
      Name
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Age
      Condition
      Is Less Than
      Field
      Value
      Sequence
      4
      Name
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      5
      Name
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      6
      Name
      TC1 Current QP Start, Txn Date
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Greater Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
    18. Click the Actions view tab.
    19. Add a new record to the Actions list, and enter the values in the following table.
      Field
      Value
      Sequence
      1
      Name
      RTC Automatic
      Type
      RTC Automatic
  8. Create the fourth rule for this promotion:
      Field
      Value
      Sequence
      4
      Name
      Retro Txns 1 month ago D
      Apply To
      Transactions
      Field
      Value
      Sequence
      1
      Name
      Check Txn Points
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Points
      Condition
      Is Greater Than
      Field
      Value
      Sequence
      2
      Name
      Is Qualifying?
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Is Qualifying
      Condition
      Equals
      Field
      Value
      Sequence
      3
      Name
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Age
      Condition
      Is Less Than
      Field
      Value
      Sequence
      4
      Name
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      5
      Name
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      6
      Name
      TC2 Current QP Start, Txn Date
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Greater Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      1
      Name
      RTC Automatic
      Type
      RTC Automatic
  9. Create the fifth rule for this promotion:
      Field
      Value
      Sequence
      5
      Name
      Retro Txns 1 -3 months ago
      Apply To
      Transactions
      Field
      Value
      Sequence
      1
      Name
      Check Txn Points
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Points
      Condition
      Is Greater Than
      Field
      Value
      Sequence
      2
      Name
      Is Qualifying?
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Is Qualifying
      Condition
      Equals
      Field
      Value
      Sequence
      3
      Name
      Transaction Age, 1 Month
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Age
      Condition
      Is Greater Than
    11. Add a new record to the Values list and enter 29 in the Value field.
      Field
      Value
      Sequence
      4
      Name
      Transaction Age < 3 Months
      Type of Comparison
      Compare to Values
    13. In the Compare to Values Detail form, enter the values in the following table.
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Age
      Condition
      Is Less Than
    14. Add a new record to the Values list and enter 90 in the Value field.
    15. Add another new record to the Criteria list, and enter the values in the following table.
      Field
      Value
      Sequence
      5
      Name
      Type of Comparison
      Compare to Object
    16. In the Compare to Object Detail form, enter the values in the following table.
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
    17. Add another new record to the Criteria list, and enter the values in the following table.
      Field
      Value
      Sequence
      6
      Name
      Type of Comparison
      Compare to Object
    18. In the Compare to Object Detail form, enter the values in the following table.
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
    19. Click the Actions view tab.
    20. Add a new record to the Actions list, and enter the values in the following table.
      Field
      Value
      Sequence
      1
      Name
      RTC Automatic
      Type
      RTC Automatic
  10. Create the sixth rule for this promotion:
      Field
      Value
      Sequence
      6
      Name
      Retro Txns 3 - 8 months ago
      Apply To
      Transactions
      Field
      Value
      Sequence
      1
      Name
      Check Txn Points
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Points
      Condition
      Is Greater Than
      Field
      Value
      Sequence
      2
      Name
      Is Qualifying?
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Is Qualifying
      Condition
      Equals
      Field
      Value
      Sequence
      3
      Name
      Transaction Age, 3 Months
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Age
      Condition
      Is Greater Than
    11. Add a new record to the Values list and enter 89 in the Value field.
      Field
      Value
      Sequence
      4
      Name
      Transaction Age < 8 Months
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Age
      Condition
      Is Less Than
    14. Add a new record to the Values list and enter 240 in the Value field.
      Field
      Value
      Sequence
      5
      Name
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      6
      Name
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Less Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      1
      Name
      RTC Manual
      Type
      RTC Manual
  11. Create the seventh rule for this promotion:
      Field
      Value
      Sequence
      7
      Name
      Retro Txns, 8 months
      Apply To
      Transactions
      Field
      Value
      Sequence
      1
      Name
      Check Txn Points
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Points
      Condition
      Is Greater Than
      Field
      Value
      Sequence
      2
      Name
      Is Qualifying?
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Is Qualifying
      Condition
      Equals
      Field
      Value
      Sequence
      3
      Name
      Transaction Age, 8 months
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Age
      Condition
      Is Greater Than
    11. Add a new record to the Values list and enter 239 in the Value field.
    12. Click the Actions view tab.
    13. Add a new record to the Actions list, and enter the values in the following table.
      Field
      Value
      Sequence
      1
      Name
      RTC Adjust Qualifying Points
      Type
  12. Create the eighth rule for this promotion:
      Field
      Value
      Sequence
      8
      Name
      Retro Txns Prior to Previous QP TC2
      Apply To
      Transactions
      Field
      Value
      Sequence
      1
      Name
      Check Txn Points
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Points
      Condition
      Is Greater Than
      Field
      Value
      Sequence
      2
      Name
      Is Qualifying?
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Is Qualifying
      Condition
      Equals
      Field
      Value
      Sequence
      3
      Name
      TC2 Previous QP Start, Txn Date
      Type of Comparison
      Compare to Object
    10. In the Compare to Object Detail form, enter the values in the following table.
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Greater Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
    11. Click the Actions view tab.
    12. Add a new record to the Actions list, and enter the values in the following table.
      Field
      Value
      Sequence
      1
      Name
      Type
  13. Create the ninth rule for this promotion:
      Field
      Value
      Sequence
      9
      Name
      Retro Txns Prior to Previous QP TC1
      Apply To
      Transactions
      Field
      Value
      Sequence
      1
      Name
      Check Txn Points
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Transaction Points
      Condition
      Is Greater Than
      Field
      Value
      Sequence
      2
      Name
      Is Qualifying?
      Type of Comparison
      Compare to Values
      Field
      Value
      Object
      Transaction
      Attribute
      Is Qualifying
      Condition
      Equals
      Field
      Value
      Sequence
      3
      Name
      TC1 Previous QP Start, Txn Date
      Type of Comparison
      Compare to Object
      Section
      Field
      Value
      Compare this object
      Object
      Member
      Compare this object
      Attribute
      Compare this object
      Condition
      Is Greater Than
      To this object
      Object
      Transaction
      To this object
      Attribute
      Transaction Date
      Field
      Value
      Sequence
      1
      Name
      Type
  14. Click Activate to activate the Admin - Retro Accrual promotion.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
