Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Programs > Siebel Loyalty Batch Engine Parameters > Configuring Batch Engine Parameters for Statements for Use with LDAP AuthenticationYou can use batch engine parameters with the object type of Statement to control the processing of Loyalty statements. However, if you use LDAP for authentication, then you must configure the application by updating the following user properties in the LOY Statement business service: If you have not enabled LDAP, then this configuration is not necessary. You can use batch engine parameters with the object type of Statement without this configuration. For more information about LDAP authentication, see Siebel Security Guide. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
