Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Programs > Siebel Loyalty Batch Engine Parameters >
Deleting Batch Engine Parameters
After you have used batch engine parameters in a run and you do not want them to apply to following runs, delete them using the following procedure. To delete batch engine parameters
- Navigate to the Administration - Loyalty Programs screen, Engine Parameters view.
- Click the Transaction Parameters, Tier Parameters, Bucket Parameters, or Statement Parameters view tab.
- Delete Parameter records.
- Shut down and restart the server component.
