Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Transient Variables >
Defining Transient Variables for User-Defined Attributes
Transient variables for user-defined attributes can be defined like other variables and can be of the type integer, text or date. They can be used in a Promotion-Designer-enabled promotion for subsequent promotions to use as input in criteria or actions. Transient variables for user-defined attributes are not created automatically. You can create them using the following procedure.
To define a transient variable for a user-defined attribute
  1. Navigate to the Loyalty Program Administration screen.
  2. Drill-down on a program.
  3. Click the Program Level Attributes tab.
  4. Click the Transient Attributes tab.
  5. Click New.
  6. Complete the necessary fields. Some fields are described in the following table.
    Field
    Description
    Name
    Name of the transient variable
    Data Type
    Transient variable data type
    Default Value
    Default Value
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
