Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > About Simulating Loyalty Transactions >
Simulating Existing Processed Transactions
This topic explains how to perform a simulation using existing processed transactions.
To perform a simulation of existing transactions
  1. Navigate to the Loyalty Promotions Administration screen, then the Programs view.
  2. Click a Program ID.
  3. Select the Simulate Transaction Details tab.
  4. Select the Simulate Existing Transactions tab.
  5. Query to find the transactions that you want.
    NOTE:  Only processed transactions are searched.
  6. Select one or more transactions.
  7. Click Simulate.
  8. Enter the Output Batch Size and Reason code in the Output Batch Size dialog box.
  9. Click Submit.
  10. To view the simulation result, navigate to the Loyalty Transaction screen, then the Transaction Id, and Detailed Processing Log view.
    Simulations of existing transactions are not saved as XML files and can only be seen in this view.
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
