Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Loyalty Promotion Examples >
Example of Creating a Simple Frequency Promotion
A simple frequency promotion requires a member to complete some action a specific number of times to receive a bonus. In this example, the member must fly from SFO to LAX three times to receive 3,000 bonus points, and the member gets the bonus as soon as the required number of flights has been reached. This example assumes that you have already created the loyalty program and the product needed for this promotion. This example shows one possible use of simple frequency promotions. Your use of these promotions can differ, depending on your business model. NOTE: When a simple frequency loyalty promotion is defined, an action must be defined to update the attribute in the attribute rule of the promotion. If this action is not added, then the bonus can be given out repeatedly.
To create a simple frequency promotion, perform the following tasks. Creating the Promotion Record for the Simple Frequency Promotion
The promotion record is a container for all the other information about the promotion. To create the promotion record
- Navigate to the Loyalty Promotions Administration screen.
- Add a new Promotion record, and complete the necessary fields. Some fields are shown in the following table.
Name |
Simple Frequency SFO-LAX Promotion |
Always Apply |
Yes |
Apply To |
Accrual-Product |
Product Inclusion |
Include Products |
Specifying the Product for the Promotion
Because this promotion applies only to airline flights, you selected Include Products in the Product Inclusion when you created the promotion. Now you must specify the product it applies to. To specify the product for this promotion
- Click the Promotion Number (#) field.
- Click the Products view tab.
- Add a new Product record, and complete the necessary fields. Some fields are shown in the following table.
NOTE: If this product does not exist in your database, then you must create it and make it available to Siebel Loyalty. For more information, see Defining Loyalty Products, Price Lists, and Catalogs.
Creating the Attribute to Track Number of Flights
You must create an attribute that tracks the number of times the member has flown from SFO to LAX, so it can be used in the promotion's rule. This rule is the first rule in the promotion because if a member completes a flight that qualifies the member for the bonus, then the actions must be taken in the following order:
- Update the number of flights attribute.
- Evaluate the attribute to see whether the member has completed the required number of flights.
- If so, give the member the bonus.
To create the attribute to track number of flights
- Click the Promotion-Specific Attributes view tab.
- Add a new Promotion-Specific Attribute record, and complete the necessary fields. Some fields are shown in the following table.
Name |
SFO-LAX Simple Freq Promo Att |
Field |
Number 1 |
Default |
0 |
Data Type |
Number |
- When you have finished creating the attribute, select the Active check box.
Creating an Attribute to Track Whether a Member Received This Bonus
If you want a member to be able to receive the bonus only once during the promotion period, then create a promotion-specific attribute that tracks whether the member was given the bonus. NOTE: If the member can receive the bonus multiple times during the promotion's applicability period, then only the one promotion-specific attribute described previously is required. Instead of this second attribute, you must add an action that resets the previously attribute SFO-LAX Simple Freq Promo Att to zero each time the member receives the bonus. This action is described later.
To create the attribute to track whether a member received this bonus
Name |
Member Given Simple Freq Bonus |
Field |
Text 1 |
Default |
No |
Data Type |
String |
Creating a Rule That Updates the Number of Flights Attribute
You must create a rule that increments the value of this attribute every time the member flies from SFO to LAX. To create a rule that updates the number of flights attribute
- Click the Rules view tab.
- In the Rules list, add a new record, and complete the necessary fields. Some fields are shown in the following table.
Sequence |
1 |
Name |
Update SFO-LAX Simple Freq Promo Attribute |
Apply To |
Transactions |
- Click the rule's Name field hyperlink.
- Add a new Criteria record, and complete the necessary fields shown in the following table.
Sequence |
1 |
Name |
Partner is Indigo Airways |
Type of Comparison |
Compare to Values |
Object |
Transaction |
Attribute |
Partner |
Condition |
Equals |
Value |
Indigo Airways |
NOTE: If desired, you could add additional criteria, such as ticket class.
- Click the Actions view tab.
- Add a new Action record, and complete the necessary fields in the Action list and Detail form, shown in the following table.
This action increments by one the promotion-specific attribute that tracks the member's number of flights every time an applicable flight is completed.
Name |
Update SFO-LAX Simple Freq Promo Attribute by 1 |
Type |
Update Attribute |
Update this attribute: Object |
Promotion |
Update this attribute: Attribute |
Update this attribute: Action |
Add |
Value |
1 |
Creating a Rule That Gives the Member a Bonus
You must also create a rule that gives the member a bonus when the attribute reaches 3, the number of flights required to receive the bonus. If the member can only receive the bonus once, then you also need a second criterion that checks whether the member has not yet received a bonus as result of this promotion. To create a rule that gives the member a bonus
- In the thread bar, click Promotion:Simple Frequency SFO-LAX Promotion.
- Add a new Rule record, and complete the necessary fields. Some fields are shown in the following table.
Sequence |
2 |
Name |
Give 3,000 Bonus When Fly SFO-LAX 3 Times |
Apply To |
Attributes |
- In the Criteria list, add a new Criteria record, and complete the necessary fields in the record, its Detail form, and its Value list, shown in the following table.
Sequence |
1 |
Name |
If SFO-LAX Promo Attribute equals 3 |
Compare to Values |
Object |
Promotion |
Attribute |
SFO-LAX Simple Freq Promotion Attribute |
Condition |
Equals |
Value |
3 |
Sequence |
2 |
Name |
Member has not yet received bonus |
Compare to Values |
Object |
Promotion |
Attribute |
Condition |
Equals |
Value |
No |
This action gives the member the 3,000-point bonus.
Sequence |
1 |
Name |
Give 3000 Regular Point Bonus |
Type |
Assign Points |
Point Type |
Regular |
Value |
3000 |
Creating an Action That Resets an Attribute Value
If you want the member to receive this bonus only once, then add an action to change the promotion-specific attribute which tracks whether the member has received the bonus to Yes. If you want the member to be able to receive this bonus multiple times, then add an action to reduce the number of flights attribute to zero. Then, after additional flights, increase this attribute until it reaches three again, and the member receives the bonus again. NOTE: Create only one of these two actions, depending on whether you want to give members the bonus multiple times or just one time.
To create an action that resets an attribute value
- To set the attribute tracking whether the member has received the bonus to yes, add a new Action record, and complete the necessary fields in the Action list and Detail form, shown in the following table.
Not applicable |
Sequence |
3 |
Not applicable |
Name |
Set Bonus Given Prom-Spec Att to Yes |
Not applicable |
Type |
Update Attribute |
Update this attribute |
Object |
Promotion |
Attribute |
Action |
Set |
And/Or this value |
Value |
Yes |
- To reset the number of flights attribute to zero, add a new Action record, and complete the necessary fields in the Action list and Detail form, shown in the following table.
Not applicable |
Sequence |
2 |
Not applicable |
Name |
Set SFO-LAX PS Att to Zero |
Not applicable |
Type |
Update Attribute |
Object |
Promotion |
Attribute |
Action |
Set |
And/Or this value |
Value |
0 |
Activating the Promotion
Now, you are ready to activate the promotion. To activate the promotion
- In the Promotion form, click Activate.
The promotion is active during the period between the start date and the end date.
