Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Loyalty Promotion Examples > Example of Creating a Joint Accrual PromotionA joint accrual promotion gives a member and corporate partners points for joint accruals. In a joint accrual promotion, the points are calculated using the distance table and base promotion or from product points. The points to be given to the individual member or corporate member are calculated using the Admin - Accrual promotion. The rules given below must also be part of the Admin - Accrual promotion. For example, you might have two companies where one company needs to be given 50% of the distance flow to the corporate account and 50% to the individual member and the other company needs to accrue 40% to the corporate account and 60% to the individual. It is recommended that you take into account the corporate reference number while defining the rules for this promotion. This example assumes that you have already created the loyalty program, including the products used by the program. Creating the Promotion RecordAs the first step, you must create a promotion record for the joint promotion. To create the promotion record
Creating Rules to Reward Individual and Corporate MembersIf the accrual type for an account is both, then by default the corporate member gets the same number of points as the individual member. However, if the corporate member needs to be rewarded in a different point type, or with a different number of points, then a separate promotion is required. The transaction for the individual member contains the corporate member number in the Corporate Member Reference field, and the individual member must have the same corporate member number mentioned in that individual member setup. To create rules to reward individual and corporate members
Activating the PromotionNow that you have set up this promotion, you can activate it. |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
