Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Process of Creating Loyalty Promotions > Specifying Products Included in a Loyalty PromotionYou can create loyalty promotions that apply to all products or that apply only to the products you specify. When you create the Loyalty Promotion record, you must choose one of these values in the Product Inclusion field:
If you select All Products, then skip this procedure. If you select one of the other two options, then use this procedure to list the products that are included or excluded. This task is a step in Process of Creating Loyalty Promotions. To specify products included in or excluded from a promotion
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
