Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Redemptions > Process of Setting Up Nonflight Redemptions > Setting Up the Nonflight Redemption PromotionAfter you set up the static price for the redemption product using the Points view, you must set up a promotion that applies to this static price. You can use this promotion to add a discount or surcharge to the static price. The promotion must use an action of the type Redeem Points to make the price appear. NOTE: Even if you do not want to add a discount or surcharge, you must create this promotion. If you do not, then the static price does not appear. Example of a Nonflight Redemption PromotionThis topic gives one example of setting up the nonflight redemption promotion. You might use this feature differently, depending on your business model. In this example, the promotion applies a 25% discount on a camera. To set up this example, perform the following high-level steps: |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
