Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Redemptions >
Example of Creating Promotions to Assign Values to Vouchers
This topic gives one example of creating promotions to assign values to vouchers. You might use this feature differently, depending on your business model.
In this example, there is a promotion that gives members vouchers as rewards. If members spend $100, then they get a voucher that is good for a $10 discount. If members spend $200, then they get a voucher that is good for a 10% discount.
To create a promotion to assign a value to a voucher
  1. Create a generic voucher in the usual way, as described in Creating Vouchers for Loyalty Members. Some fields are described in the following table.
    Field
    Description
    Name
    Discount Voucher
    Type
    Electronic Voucher
  2. Create the promotion in the usual way, described in Process of Creating Loyalty Promotions.
  3. For the first rule for the promotion, create a criterion that applies the rule to purchases greater than $100 and less than $200, and create an Action that gives the Voucher the absolute value of $10 discount:
    1. Navigate to the Loyalty Promotion Administration screen, then the Promotion, Rule, and Action view.
    2. In the Action view, complete the necessary fields, described in the following table.
      Field
      Description
      Voucher
      Discount Voucher
      Discount Type
      Absolute Value
      Voucher Discount Value
      10
      Currency
      USD
  4. For the second rule for the promotion, create a criterion that applies the rule to purchases greater than $200, and create an action which gives the Voucher the value of 10% discount:
      Field
      Description
      Voucher
      Discount Voucher
      Discount Type
      Percentage
      10
      Currency
      not applicable
Siebel Loyalty Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
