Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Redemptions > Points-To-Pay Conversion > Setting Up Points-To-Pay ConversionThe points-to-pay conversion pricing is optional for loyalty programs. To enable points-to-pay conversion, you need to check the points-to-pay field at the loyalty program level. Siebel Loyalty determines whether it is required to convert points to pay based on this field as well as the set of conditions described in About Points-To-Pay Conversion. The most basic of these conditions is that the member does not have a sufficient balance even after considering the eligible loan to that member. The business service, called after a member has selected a price option, checks Loyalty Program Administration to verify whether to convert points to pay. This process then recalculates the pricing and returns a new price in line with the member's point balance. The difference in the initial redemption price in points and the member's point balance is converted to the pay component. To set up points-to-pay conversion
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
