Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Redemptions > Process of Setting Up Airline Flight Redemptions > Creating the Flight Redemption ProductFor an airline flight redemption, most frequent flyer programs only create one generic flight redemption product instead of creating products for each segment (for example, LHR-BOM), because they define redemption based on flight distance or on the departure and arrival zones. NOTE: If you define pricing in points, then you must create a separate flight redemption product for each segment, and you must define the pricing separately for each of these product. The flight redemption product is not usually an electronic voucher, but it can be. If you are creating a product of the type Electronic Voucher, then see Creating Vouchers for Loyalty Members. This task is a step in Process of Setting Up Airline Flight Redemptions. To create the flight redemption product
Related Book |
| Siebel Loyalty Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
