Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > Process of Configuring the Bounce Handler Daemon > Verifying the Bounce Handler Daemon InstallationTo verify that the Bounce Handler Daemon installation was successful, you start the Bounce Handler Daemon and then perform installation tests. This topic describes these tasks. For information about testing how the Email Marketing components and the Marketing Component Group work together, see Process of Testing the Email Marketing Components with Siebel Marketing. This task is a step in Process of Configuring the Bounce Handler Daemon. Starting the Bounce Handler Daemon on a Windows ServerTo start the Bounce Handler Daemon on a Windows server, perform the steps in the following procedure. To start the Bounce Handler Daemon on a Windows Server
Starting the Bounce Handler Daemon on a UNIX ServerTo start the Bounce Handler Daemon on a UNIX server, perform the steps in the following procedure. To start the Bounce Handler Daemon on a UNIX server
The first command (./bin/bhd-ctl.sh start &) launches the daemon. The second command (tail -f bhd.log) displays output to the bhd log as it is running without generating a read lock on the file. A read lock would prevent these commands from working. Verifying the Bounce Handler Daemon InstallationTo verify the Bounce Handler Daemon installation, perform the steps in the following procedure. To verify the Bounce Handler Daemon installation
Siebel Marketing Installation and Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
