Aaccess groups, Marketing 1 activity plans, creating 1 activity templates, creating 1 administrator alerts, setting up 1 Apache Tomcat, upgrading 1 approval process Action value, adding 1 Approval Status value, adding 1 mapping Approval Status value to Action value 1 automatic responses, for opportunities and orders 1 Bbounce codes 1 Bounce Handler daemon (BHD) configuring 1 configuring bounce classification 1 testing, verifying 1 Business Intelligence Presentation server connecting to Siebel server 1 user ID and password 1 Ccampaign history table campaign load table update rules (table) 1 contents of 1 campaign load formats creating 1 integration objects 1 options 1 campaign load mappings about 1 campaign load table update rules (table) 1 Contact Key components, sample mappings (table) 1 mapping rules for Marketing Contact integration components 1 mapping rules for Marketing Person integration components 1 mapping rules for Marketing prospect integration components 1 Marketing integration objects, about and diagram 1 Marketing Person integration component description (table) 1 Marketing Person integration object, about 1 Siebel contact and campaign history tables, about and list of tables 1 Campaign Load workflow process, configuring 1 campaign load, testing 1 campaigns, upgrading 1 character sets, Email Marketing server 1 CKEditor file manager, configuring 1 Click Through daemon (CTD) configuring HTTP server port 1 installing 1 testing, verifying 1 component configuration Email Marketing server 1 testing 1 component groups enabling 1 group status, determining 1 synchronizing 1 configuration, Marketing approval process 1 Contact List Import Using PL/SQL about 1 installing 1 Ddeployment, global 1 distribution method, vendor task 1 distribution profiles vendor task, described 1 vendors, defining for 1 Eemail address header, configuring 1 email addresses, configuring the status of 1 email jobs monitoring 1 prioritization workflow 1 prioritizing 1 Email Marketing architecture, graphic 1 Bounce Handler daemon, about 1 character sets 1 Click Through Daemon, about 1 configuring email address header 1 configuring for HTTPS communications 1 email delivery, example of 1 Email Sending daemon, about 1 Email Sending daemon, graphic 1 final test 1 frequently used terms 1 installation issues 1 installing and configuring, about 1 installing, about 1 installing, requirements for 1 Java Development Kit, installing 1 log files 1 testing with Siebel Marketing 1 verifying component configuration 1 Email Marketing daemons, configuring 1 Email Marketing, administering configuring logging 1 disabling SMTP command pipelining 1 prioritizing jobs 1 setting ESD throughput rate 1 setting up administrator alerts 1 tasks 1 using the Jobs console 1 Email Sending daemon (ESD) accessing Marketing File System 1 configuring 1 configuring connection 1 failover 1 installing 1 outbound mail transfer agent 1 setting a maximum throughput rate 1 testing, verifying 1 email templates, implementing spam scoring 1 email treatments, editing 1 entity relationships 1 events base URL, configuring 1 Ffield names for marketing integration components 1 file sharing in mixed environments 1 frames, implementing Web Marketing without frames 1 Gglobal deployment about 1 Web Marketing 1 Hhost URL, Marketing module 1 HTML frames, implementing Web Marketing without frames 1 HTTP server port, configuring 1 HTTPS communications, Email Marketing components 1 IImporting a Contact List Using PL/SQL 1 integration components, mapping rules (Marketing Contact) 1 integration Ids 1 JJobs console accessing 1 using 1 Llead load format 1 links, testing 1 load balancing 1 log files configuring logging 1 Email Marketing 1 logical entity relationships 1 MMarketing access groups about 1 assigning users to 1 creating new 1 modifying privileges 1 Marketing activity plans, creating 1 Marketing activity templates, creating 1 Marketing administrators access groups, user's position, about adding to 1 Marketing approval process, configuring 1 marketing connection settings, updating 1 Marketing Contact integration object about 1 mapping rules 1 User Key fields, about 1 Marketing File System configuring the Email Sending daemon 1 setting up 1 marketing integration components, field names 1 Marketing integration objects about and diagram 1 Contact Key components, sample mappings (table) 1 Marketing Lead object 1 Marketing Person integration component description (table) 1 Marketing integration objects, used for campaign loading 1 Marketing module testing in integrated environment 1 URLs for 1 Marketing Person integration object about 1 component description (table) 1 integration components (table) 1 mapping rules 1 mapping scenarios 1 note, about ID required to confirm person in db 1 Marketing Prospect integration objects about 1 mapping rules 1 Marketing regions, creating 1 Marketing responsibilities 1 , 2 Marketing server components component group status, determining 1 component groups, enabling 1 component groups, synchronizing 1 Marketing system tasks, monitoring 1 Marketing workflow process creating manager component 1 isolating 1 mixed environments, file sharing 1 monitoring system tasks 1 multilingual deployment, Web Marketing 1 Ooffers, deleting 1 opportunities, enabling automatic responses 1 orders, enabling automatic responses 1 outbound mail transfer agent 1 output file layouts, working with vendor task, about 1 Ppassword, Business Intelligence Presentation server 1 permissions 1 personalization, using with Web Marketing 1 phone offers, deleting 1 privileges for Marketing access groups 1 Rregions, creating 1 relationships, logical entity 1 responses management, about 1 responses, automatic 1 responsibilities Marketing 1 setting up for Web Marketing 1 restarting Siebel Server using Microsoft Windows 1 SSegment Designer page, testing links to 1 Siebel contact table about and list of tables 1 campaign load table update rule (table) 1 Siebel Marketing about installing 1 administering 1 component groups and components, setting up 1 starting Siebel Server 1 using with Siebel Open UI 1 workflow processes, activating 1 Siebel Marketing, initializing component groups, enabling 1 component groups, synchronizing 1 opportunities and orders, enabling automatic response 1 Siebel Open UI, using 1 Siebel Personalization, using with Web Marketing 1 Siebel Server connecting to Business Intelligence Presentation server 1 restarting using Microsoft Windows 1 Siebel Web Engine, about 1 SMTP command pipelining, disabling 1 SMTP configuration 1 SOAP communications port, configuring 1 Source Code Formats list about 1 reordering list 1 source code formats, creating about source codes 1 creating source code formats 1 source code format components, defining 1 Source Code Formats list, viewing available formats 1 ways to use, about 1 spam scoring, implementing 1 SpamAssassin, integrating with Email Marketing 1 symbolic URL Marketing module 1 testing 1 synchronizing component groups 1 system data expressions, enabling 1 system tasks, monitoring 1 Ttesting Bounce Handler daemon 1 campaign load 1 Click Through Daemon 1 creating email template 1 email contacts 1 Email Sending daemon 1 email sending to test contacts 1 Marketing module 1 navigation links 1 symbolic URL 1 Web Services integration 1 UUniversal Time 1 updating marketing connection settings 1 URL base URL, configuring 1 host and symbolic URL for Marketing module 1 user ID, Business Intelligence Presentation server 1 user interface, customizing about 1 full-text search, about 1 response management, about 1 Web Marketing without frames, implementing 1 Web templates, using 1 Vvendor profiles, setting up creating 1 defining vendors and assigning list distribution method 1 distribution profiles, defining for vendors 1 multiple list formats, handling 1 vendor tasks, list of 1 vendors defined 1 vendors defined 1 multiple list formats, handling 1 WWeb Anonymous User responsibility, about 1 Web Corporate User responsibility, about 1 Web Marketing, configuring 1 Web Marketing, setting up and using about 1 home page, accessing by visitors 1 installing, applications to install before Web Marketing 1 responsibilities and users, setting up default 1 Siebel Personalization, using with Web Marketing 1 user access, tasks to control user access 1 user interface, customizing 1 Web site visitor, about 1 Web offers, deleting 1 Web Registered User responsibility, about 1 Web Services integration, testing 1 Web site user access, tasks to control user access 1 visitor, about 1 Web Marketing home page, accessing by visitors 1 Web Survey daemon 1 Web templates, using to customize the user interface 1 Windows, restarting Siebel Server 1 workflow process activating 1 isolating 1 |
| Siebel Marketing Installation and Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
