 Siebel Marketing Installation and Administration Guide > Installing and Administering Siebel Marketing >
Installing Siebel Marketing
A Siebel Marketing installation has two main parts. You can install the following parts in any sequence:
- (Required) The Siebel Marketing operational application, including the Siebel Server.
For more information about installing Siebel Server components, see the Siebel Installation Guide for the operating system you are using. For information about Web servers and operating systems, see the Certifications tab on My Oracle Support. If you are upgrading an existing Marketing installation, see Siebel Database Upgrade Guide.
 - (Optional) Oracle Business Intelligence Server components that provide segmentation and list generation capabilities. These components are referred to as the Marketing module. For more information about installing the Marketing module, see Oracle Marketing Segmentation Guide.
NOTE:  The Siebel Bookshelf is available on Oracle Technology Network (http://www.oracle.com/technetwork/indexes/documentation/index.html) and Oracle Software Delivery Cloud. It might also be installed locally on your intranet or on a network location.
