Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > Installing the Email Marketing Server >
Installing the Click Through Daemon
This topic contains the information that you need to install the Click Through Daemon. Before installing the Click Through Daemon, make sure that you have completed the installation requirements. For more information, see Requirements for Installing Email Marketing.
To install the Click Through Daemon on a Windows or UNIX server
  1. On a Windows server, run the Click Through Daemon installation program.
  2. On a UNIX server, perform the following steps:
    1. Make an installation directory named ctd using the following command:
    mkdir ctd
    1. Copy the Click Through Daemon installation program from the installation media to the directory that you created.
    2. In the Click Through Daemon installation directory, run the Click Through Daemon installation program.
  3. In the Installation dialog box, review the information, and then click Next.
  4. In the Choose Java Virtual Machine dialog box, select the Java Development Kit (JDK) that you installed in Requirements for Installing Email Marketing, and then click Next.
    NOTE:  Make sure that you choose the correct JDK. Selecting the wrong JDK or selecting a JRE prevents the Click Through Daemon from starting properly.
  5. In the Choose Install Folder dialog box, choose the Click Through Daemon installation directory, and then click Next.
  6. Review the Pre-Installation Summary dialog box, and then click Install.
  7. In the Install Complete dialog box, verify the information, and then click Done.
Siebel Marketing Installation and Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
