Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > Roadmap for Configuring Email Marketing DaemonsThis topic contains the information that you need to configure Email Marketing Server and the Siebel Marketing application so that they can communicate with each other. To configure the Email Marketing daemons, perform the following tasks and processes:
Before You BeginMany of the configuration values you must specify for the Email Marketing daemons are specified in the properties file for the component, for example, the URL used to connect the Email Sending Daemon to Siebel Marketing, the location of the Siebel File System, and various other parameters that control the behavior of the Email Marketing components. The component properties files, esd.properties, bhd.properties, and ctd.properties, are located in the ESD_root, BHD_root, and CTD_root installation directories, respectively. For additional information about the properties files, see New and Changed Properties in the esd.properties Configuration File. |
| Siebel Marketing Installation and Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
