Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > Process of Configuring the Email Sending Daemon > Configuring the SOAP Communications PortThe Marketing application on Siebel Server communicates with the Email Sending Daemon using the SOAP protocol, which uses HTTP requests. You must configure the Email Sending Daemon to listen for these HTTP requests on a specific port. This task is described in the following procedure. This task is a step in Process of Configuring the Email Sending Daemon. To configure the SOAP communications port
| Siebel Marketing Installation and Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
