Siebel Marketing Installation and Administration Guide > Designing Marketing Campaign Load Formats > About Marketing Integration Objects > About the Marketing Prospect Integration ObjectThe Marketing Prospect integration object provides field mappings to typical prospect information from marketing data source(s). The required fields are fields that cannot be a null value for the new record. Figure 2 shows the integration components for the Marketing Prospect integration object. Required fields apply when a new prospect is inserted into the Siebel transactional database. For a list of fields for the Marketing Prospect integration object, see Field Names for Marketing Integration Components. Table 13 describes the Marketing Prospect Integration components. NOTE: Required fields apply when a new contact is inserted into the Siebel transactional database. Mapping Rules for the Marketing Prospect Integration ComponentsUsing prospect information for a campaign load requires the following integration components:
| Siebel Marketing Installation and Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
