Table 5.	Workflow Processes Required for Siebel Marketing
    Analytics Data Load  |
    Marketing  |
    Loads data through EAI for Customer Synchronization or Analytics Data Load requests.  |
    Business Rules Workflow   |
    Marketing  |
    Invokes lead rules.  |
    Campaign Copy  |
    Marketing  |
    Applies a campaign template.  |
    Email Marketing - Forward to Friend  |
    Marketing  |
    Sends new emails to forward recipients.  |
    Email Marketing - Update Status  |
    Marketing  |
    Updates the delivery status of an email offer.  |
    Event Stage Execution Workflow   |
    Marketing  |
    Performs the scheduled execution of an event stage.  |
    Generate Source Code  |
    Marketing  |
    Generates source codes for a campaign.  |
    Import Marketing Contact  |
    Marketing  |
    Subprocess for Marketing Campaign Load.  |
    Lead To Opty Conversion   |
    Marketing  |
    Converts a lead to an opportunity.  |
    List Export  |
    Marketing  |
    Requests list files to be generated by the Marketing module.  |
    List Export (Internal)  |
    Marketing  |
    Generates list files for sending email offers using basic mode.  |
    List Purge  |
    Marketing  |
    Purges prospects from an internal list.  |
    Marketing Approval Process  |
    Marketing  |
    Routes marketing approval items.  |
    Marketing Campaign Launch  |
    Marketing  |
    Starts one or more campaign waves.  |
    Marketing Campaign Load  |
    Marketing  |
    Loads segment or list members into a campaign.  |
    Marketing Create Lead   |
    Marketing  |
    Creates leads.  |
    Marketing Create Response   |
    Marketing  |
    Creates responses.  |
    Marketing Stage Execution  |
    Marketing  |
    Scheduled execution of a program stage.  |
    Marketing Wave Launch  |
    Marketing  |
    Subprocess for Marketing Campaign Launch.  |
    Mktg Import - Account Process  |
    Marketing   |
    Allows multi-threaded batch import of accounts from an external file to core Siebel CRM tables. This workflow is invoked from the Mktg Master Import Process workflow.  |
    Mktg Import - Contact Process  |
    Marketing   |
    Allows multi-threaded batch import of contacts from an external file to core Siebel CRM tables. This workflow is invoked from the Mktg Master Import Process workflow.  |
    Mktg Import File Processing   |
    Marketing  |
    Processes files for import. This workflow is invoked from the Mktg Master Import Process workflow.  |
    Mktg Import - Lead Process  |
    Marketing  |
    Allows multi-threaded batch import of leads from an external file to core CRM tables. This workflow is invoked from the Mktg Master Import Process workflow.  |
    Mktg Import - Prospect Process  |
    Marketing   |
    Allows multi-threaded batch import of prospects from an external file to core CRM tables. This workflow is invoked from the Mktg Master Import Process workflow.  |
    Mktg Import - Response Process  |
    Marketing   |
    Allows multi-threaded batch import of responses from an external file to core Siebel CRM tables. This workflow is invoked from the Mktg Master Import Process workflow.  |
    Mktg Master DB Import Process  |
    Marketing  |
    Required for Contact List Import using PL/SQL.  |
    Mktg Master Import Process   |
    Marketing  |
    This workflow is the entry point for processing all import objects. The workflow launches processes by reading job details.  |
    Post-Launch Custom Workflow   |
    Marketing Custom Workflows  |
    This is the custom workflow for post-launch tasks which can be executed immediately after launching a campaign. You can customize this workflow to add your own validation or business logic.  |
    Post-Load Custom Workflow   |
    This is the custom workflow for post-load tasks which can be executed immediately after loading a campaign. You can customize this workflow to add your own validation or business logic.  |
    Pre-Load Custom Workflow   |
    This is the custom workflow for pre-load tasks which can be executed before the Campaign Load process. You can customize this workflow to add your own validation or business logic.  |
    Program Copy  |
    Marketing  |
    Applies a program template.  |
    Program Prioritization Workflow   |
    Marketing  |
    Manages cross-program prioritization while executing event triggers.  |
    Promote Prospect (Many)  |
    Marketing  |
    Promotes multiple prospects to contacts.   |
    Promote Prospect (Single)  |
    Marketing  |
    Promotes a single prospect to a contact.  |
    Purge Staging Process   |
    Marketing  |
    Purges the staging tables used for the import process.  |
    Response To Lead Conversion   |
    Marketing  |
    Converts a response to a lead.  |
    Response To Opty Conversion   |
    Marketing  |
    Converts a response to an opportunity.   |
