Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > Upgrading Apache Tomcat ManuallyWhen you install Siebel Marketing, Apache Tomcat, used with Siebel Email Marketing, is also installed. The version of Apache Tomcat that is installed depends on your Siebel Marketing release:
If you want to take advantage of security updates included in later versions of Apache Tomcat, you can update the version of Apache Tomcat you received with Siebel Marketing. For example, for Siebel CRM 8.1 and later, you can upgrade to Apache Tomcat 7.0.40, or for Siebel CRM 8.0, you can upgrade to Apache Tomcat 6.0.37. The following procedure describes how to manually upgrade your version of Apache Tomcat. To upgrade Apache Tomcat manually
| Siebel Marketing Installation and Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
