Siebel Marketing Installation and Administration Guide > Installing and Administering Siebel Marketing > Load Balancing and Global Deployment of Siebel MarketingFor information about load balancing server requests within the Siebel Enterprise, see Siebel Installation Guide for the operating system you are using and Siebel System Administration Guide. Isolating Marketing Workflow ProcessesMarketing workflow processes can be resource intensive during peak usage or large jobs. You might need to isolate marketing-related workflows from other workflow requests in the Enterprise by directing marketing requests to a specific instance of the Workflow Process Manager. If you need to do this for marketing workflow processes, you must replicate the Workflow Process Manager component and change the enterprise parameter so that it points to the new component. To create a new Marketing workflow process manager component
| Siebel Marketing Installation and Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
