Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > Process of Configuring the Bounce Handler Daemon > Configuring Web Services Properties for the Bounce Handler DaemonYou can configure the Web Services properties for the BHD by changing the properties in the bhd.properties file. This topic describes this task. This task is a step in Process of Configuring the Bounce Handler Daemon. To configure Web services properties for the Bounce Handler Daemon
NOTE: If the Web services endpoint URL uses the HTTPS protocol, then you must configure the Email Marketing components for HTTPS communications with Siebel Marketing as described in Configuring Email Marketing Components for HTTPS Communications. |
| Siebel Marketing Installation and Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
