Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > Process of Configuring the Click Through Daemon > Configuring Web Services Properties for the Click Through DaemonYou can configure the Web Services properties for the CTD by changing the properties in the ctd.properties file, located in the CTD_root_installation directory. This task is a step in Process of Configuring the Click Through Daemon. To configure Web services properties for the Click Through Daemon
NOTE: If the Web services endpoint URL uses the HTTPS protocol, then you must configure the Email Marketing components for HTTPS communications with Siebel Marketing as described in Configuring Email Marketing Components for HTTPS Communications. |
| Siebel Marketing Installation and Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
