Siebel Object Interfaces Reference > Browser Script Quick Reference > Object Interfaces Reference >
Document Object Model Events You Can Use
This topic describes Document Object Model events you can use. Document Object Model Events for High Interactivity Mode
Table 112 lists the Document Object Model events you can use in high interactivity mode. For each control, you can use the following events:
Note that scriptable events are not available for List Column and Tree controls.
Table 112. Document Object Model Events You Can Use in High Interactivity
Button |
Native |
None |
CheckBox |
Native |
Rendered as Input Type is CHECKBOX. |
Link |
Native |
Rendered through paired anchor tags or as INPUT TYPE is TEXT in edit mode. |
List Column |
Native |
None |
Mailto |
Native |
Rendered as anchor tags with HREF is mailto or as INPUT TYPE is TEXT in Edit mode. |
MiniButton |
Native |
None |
Password |
Native |
Rendered as Input Type is password. |
Text |
Native |
Rendered as INPUT TYPE is TEXT or as SELECT if attached to a picklist. If there is a pop-up window, then Siebel CRM renders it as an edit box plus a button. |
TextArea |
Native |
Rendered as TEXTAREA. |
Tree |
Native |
None |
URL |
Native |
Rendered through paired anchor tags with an HREF equal to the underlying field value or as INPUT TYPE is TEXT in edit mode. |
You cannot access a Siebel object from a Document Object Model event. Business components and applets are examples of Siebel objects. You can typically call code in the General section from anywhere in an object. However, you cannot call code written in the General section from a Document Object Model event. To associate a script with the control_OnClick event in high interactivity mode only, use the Applet_PreInvokeMethod event that is associated with the applet. For more information, see Using a MiniButton Control to Call a Custom Method. Document Object Model Events for Standard Interactivity Mode
Table 113 lists the Document Object Model events and template modes you can use in standard interactivity mode. The Type property for each control uses a type that is native to the browser.
Table 113. Document Object Model Events You Can Use in Standard Interactivity
Button |
You can use the following events:
- OnBlur (Base/Edit)
- OnFocus (Base/Edit)
- OnMouseOut (Base/Edit)
- OnMouseOver (Base/Edit)
Not applicable |
CheckBox |
- OnChange (Edit)
- OnFocus (Edit)
- OnMouseOut (Edit)
- OnMouseOver(Edit)
Siebel CRM renders a CheckBox control in the following ways:
- In Base mode, as a Y or N text value
- In Edit mode, as Input Type is CHECKBOX
Link |
- OnClick (Base/Edit)
Siebel CRM renders a Link control in the following ways:
- In Base mode, through paired anchor tags
- In Edit mode, as INPUT TYPE is TEXT
Mailto |
- OnChange (Edit)
Siebel CRM renders a Mailto control in the following ways:
- In Base mode, as anchor tags with HREF is mailto
MiniButton |
Not applicable |
Password |
- OnBlur (Edit)
- OnChange (Edit)
- OnFocus (Edit)
- OnMouseOut (Edit)
- OnMouseOver (Edit)
Siebel CRM renders a Password control in Edit mode as Input type is password. |
Text |
- OnBlur (Edit)
- OnChange (Edit)
- OnFocus (Edit)
- OnMouseOut (Edit)
Siebel CRM renders a Text control in the following ways:
- In base mode, as plain text, unless a pop-up window is associated with the control.
- In Edit mode, as INPUT TYPE is TEXT, unless the control is attached to a picklist. If the control is attached to a picklist, then Siebel CRM renders it as INPUT TYPE is SELECT.
TextArea |
- OnBlur (Edit)
- OnChange (Edit)
- OnFocus (Edit)
Siebel CRM renders a TEXTAREA control in the following ways:
- In Edit mode, as INPUT TYPE is TEXTAREA
URL |
- OnChange (Edit)
- In Base mode, through paired anchor tags with an HREF that is the underlying field value
Tree |
Scriptable events are not available. |
Not applicable |
List Column |
