Table 141. Summary of Application Methods for COM Data Control
Attach Method for an Application |
Allows an external application to reconnect to an existing Siebel session. |
Dim application as SiebelDataControl Dim status as Boolean status = application.Attach(sessionID As String)
CurrencyCode Method for an Application |
Returns the currency code that is associated with the division of the user position. |
Dim application as SiebelDataControl Dim sCur as String sCur = Application.CurrencyCode
Detach Method for an Application |
Returns a string that contains the Siebel session ID. |
Dim application as SiebelDataControl Dim sessionId as String sessionId = application.Detach()
EnableExceptions Method for an Application |
Enables or disables native Component Object Model (COM) error handling. |
Dim application as SiebelDataControl Dim bEnable as Boolean bEnable = true application.EnableExceptions(bEnable)
GetBusObject Method for an Application |
Creates a new instance of a business object. |
Dim application as SiebelDataControl Dim busObject as SiebelBusObject set busObject = application.GetBusObject(busobjName as String)
GetLastErrCode Method for an Application |
Returns the error code for the error that Siebel CRM logged most recently. |
Dim application as SiebelDataControl Dim iErr as Integer iErr = application.GetLastErrCode
GetLastErrText Method for an Application |
Returns the text message for the error that Siebel CRM logged most recently. |
Dim application as SiebelDataControl Dim sText as String sText = application.GetLastErrText
GetProfileAttr Method for an Application |
Returns the name of an attribute in a user profile. |
Dim application as SiebelDataControl Dim sText as String sText = application.GetProfileAttr(profileAttributeName as string)
GetService Method for an Application |
Locates a business service. If this business service is not already running, then Siebel CRM starts it. |
Dim application as SiebelDataControl Dim service as SiebelService set service = application.GetService( serviceName as String)
GetSharedGlobal Method for an Application |
Returns the shared global variables. |
Dim application as SiebelDataControl Dim sText as string sText = application.GetSharedGlobal(globalVariableName as string)
InvokeMethod Method for an Application |
Calls a method. |
Dim application as SiebelDataControl Dim sReturn as String sReturn = application.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
Login Method for an Application |
Allows an external application to log in to the COM Data Server, COM Data Control, or Siebel Java Data Bean, and to access Siebel objects. |
Dim application as SiebelDataControl Dim sErr as String sErr = application.Login(connectString as String, userName as String, password as String)
LoginId Method for an Application |
Returns the login ID of the user who started the Siebel application. |
Dim application as SiebelDataControl Dim sID as String sID = application.LoginId
LoginName Method for an Application |
Returns the login name of the user who started the Siebel application. |
Dim application as SiebelDataControl Dim sUser as String sUser = application.LoginName
Logoff Method for an Application |
Disconnects the Siebel client from the Siebel Server. |
Dim SiebApp as SiebelDataControl Dim boolVal as Boolean boolVal = siebApp.LogOff
NewPropertySet Method for an Application |
Creates a new property set. |
Dim application as SiebelDataControl Dim PropSet as SiebelPropertySet PropSet = oApplication.NewPropertySet
PositionId Method for an Application |
Returns the position ID of the user position. |
Dim application as SiebelDataControl Dim sRow as String sRow = application.PositionId
PositionName Method for an Application |
Returns the name of the current user position. |
Dim application as SiebelDataControl Dim sPosition as String sPosition = application.PositionName
SetPositionId Method for an Application |
Sets the active position to a Position ID. |
Dim application as SiebelDataControl Dim status as Boolean status = application.SetPositionId(sPosId)
SetPositionName Method for an Application |
Sets the active position to a position name. |
Dim application as SiebelDataControl Dim status as Boolean status = application.SetPositionName(sPosName)
SetProfileAttr Method for an Application |
Personalization uses this method to set a value for an attribute in a user profile. |
Dim application as SiebelDataControl application.SetProfileAttr(name as String, value as String)
SetSharedGlobal Method for an Application |
Sets a shared global variable. |
Dim SiebApp as SiebelDataControl Dim boolVal as Boolean boolVal = SiebApp.SetSharedGlobal(varName As String, value As String)
Trace Method for an Application |
Appends a message to the trace file. |
Dim SiebApp as SiebelDataControl Dim boolVal as Boolean boolVal = siebApp.TraceOn(msg As String)
TraceOff Method for an Application |
Turns off tracing. |
Dim SiebApp as SiebelDataControl Dim boolVal as Boolean boolVal=siebApp.TraceOff
TraceOn Method for an Application |
Turns on tracing. |
Dim SiebApp as SiebelDataControl Dim boolVal as Boolean boolVal = siebApp.TraceOn(fileName As String, category As String, src As String)
