Table 145. Summary of Property Set Methods for COM Data Control
AddChild Method for a Property Set |
Adds child property sets to a property set. |
Dim oPropSet as SiebelPropertySet Dim iIndex as Integer iIndex = oPropSet.AddChild( childObject as Property Set)
Copy Method for a Property Set |
Returns a copy of a property set. |
Dim oPropSet1 as SiebelPropertySet Dim oPropSet2 as SiebelPropertySet oPropSet2 = oPropSet1.Copy()
GetChild Method for a Property Set |
Returns a child property set of a property set. |
Dim oPropSet as SiebelPropertySet Dim oPropSet1 as SiebelPropertySet oPropSet1 = oPropSet.GetChild(index as Integer)
GetChildCount Method for a Property Set |
Returns the number of child property sets that exist for a parent property set. |
Dim oPropSet as SiebelPropertySet Dim iCount as Integer iCount = oPropSet.GetChildCount()
GetFirstProperty Method for a Property Set |
Returns the name of the first property in a property set. |
Dim oPropSet as SiebelPropertySet Dim sPropName as String sPropName = oPropSet.GetFirstProperty()
GetNextProperty Method for a Property Set |
Returns the name of the next property in a property set. |
Dim oPropSet as SiebelPropertySet Dim sPropName as String sPropName = oPropSet.GetNextProperty()
GetProperty Method for a Property Set |
Returns the value of a property. |
Dim oPropSet as SiebelPropertySet Dim sPropVal as String sPropVal = oPropSet.GetProperty(propName as String)
GetPropertyCount Method for a Property Set |
Returns the number of properties that exist in the current level in the hierarchy. |
Dim oPropSet as SiebelPropertySet Dim count as Long count = oPropSet.GetPropertyCount
GetType Method for a Property Set |
Returns the value of the type attribute of a property set. |
Dim oPropSet as SiebelPropertySet Dim sTypeVal as String sTypeVal = oPropSet.GetType()
GetValue Method for a Property Set |
Returns the value of the value attribute of a property set. |
Dim oPropSet as SiebelPropertySet Dim sValVal as String sValVal = oPropSet.GetValue()
InsertChildAt Method for a Property Set |
Inserts a child property set in a parent property set at a specific location. |
Dim oPropSet as SiebelPropertySet oPropSet.InsertChildAt(childObject as SiebelPropertySet, index as Long)
PropertyExists Method for a Property Set |
Returns a Boolean value that indicates if the property that the argument identifies exists. |
Dim oPropSet as Property Set Dim propExists as Boolean propExists = oPropSet.PropertyExists( propName as String)
RemoveChild Method for a Property Set |
Removes a child property set from a parent property set. |
Dim oPropSet as SiebelPropertySet oPropSet.RemoveChild(index as Long)
RemoveProperty Method for a Property Set |
Removes a property from a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.RemoveProperty(propName as String)
Reset Method for a Property Set |
Removes every property and child property set from a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.Reset()
SetProperty Method for a Property Set |
Sets a value in the property of a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.SetProperty(propName as String, propValue as String)
SetType Method for a Property Set |
Sets the value for the type attribute of a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.SetType(value as String)
SetValue Method for a Property Set |
Sets the value for the value attribute of a property set. |
Dim oPropSet as SiebelPropertySet oPropSet.SetValue(value as String)
