Table 150. Summary of Business Component Methods for the Mobile Web Client Automation Server
ActivateField Method for a Business Component |
Activates a field. |
Dim busComp as SiebelBusComp BusComp.ActivateField(fieldName as String)
ActivateMultipleFields Method for a Business Component |
Activates multiple fields. |
Dim buscomp as SiebelBusComp buscomp.ActivateMultipleFields (oPropSet as SiebelPropertySet)
Associate Method for a Business Component |
Creates a new many-to-many relationship for the parent object through an association business component. |
Dim busComp as SiebelBusComp busComp.Associate(whereIndiSiebel cator as Integer)
BusObject Method for a Business Component |
Returns the name of the business object that the business component references. |
Dim busComp as SiebelBusComp Dim busObject as SiebelBusObject Set BusObject = busComp.BusObject
ClearToQuery Method for a Business Component |
Clears the current query but does not clear sort specifications on a business component. |
Dim busComp as SiebelBusComp Dim bool as Boolean bool = busComp.ClearToQuery
DeactivateFields Method for a Business Component |
Deactivates the fields that are currently active from the SQL query statement of a business component. |
Dim busComp as SiebelBusComp Dim bool as Boolean bool = busComp.DeactivateFields
DeleteRecord Method for a Business Component |
Removes the current record from a business component. |
Dim busComp as SiebelBusComp Dim bool as Boolean bool = busComp.DeleteRecord
ExecuteQuery Method for a Business Component |
Returns a set of business component records. |
Dim busComp as SiebelBusComp Dim bool as Boolean bool = busComp.ExecuteQuery(cursorMode as Integer)
ExecuteQuery2 Method for a Business Component |
Returns a set of business component records. Allows you to control the number of records Siebel CRM returns. |
Dim busComp as SiebelBusComp Dim bool as Boolean bool = busComp.ExecuteQuery2(cursorMode as Integer, ignoreMaxCursorSize as Boolean)
FirstRecord Method for a Business Component |
Moves the record pointer to the first record in a business component, making that record the current record. |
Dim busComp as SiebelBusComp Dim bIsRecord as Boolean bIsRecord = busComp.FirstRecord
GetAssocBusComp Method for a Business Component |
Returns the name of the association business component. |
Dim busComp as SiebelBusComp Dim AssocBusComp as SiebelBusComp Set AssocBusComp = busComp.GetAssocBusComp
GetFieldValue Method for a Business Component |
Returns the value of a field from the current record of a business component. |
Dim busComp as SiebelBusComp Dim sValue as String sValue = busComp.GetFieldValue(FieldName as String)
GetFormattedFieldValue Method for a Business Component |
Returns a field value that is in the same format that the Siebel client uses. |
Dim busComp as SiebelBusComp Dim sValue as String sValue = busComp.GetFormattedFieldValue(FieldName as String)
GetLastErrCode Method for a Business Component |
Returns the error code for the error that Siebel CRM logged most recently. |
Dim buscomp as SiebelBusComp Dim iErr as Integer iErr = buscomp.GetLastErrCode
GetLastErrText Method for a Business Component |
Returns the text message for the error that Siebel CRM logged most recently. |
Dim busComp as SiebelBusComp Dim sErr as String sErr = busComp.GetLastErrText
GetMultipleFieldValues Method for a Business Component |
Returns a value for each field specified in a property set. |
Dim buscomp as SiebelBusComp buscomp.GetMultipleFieldValues(oPropSet as SiebelPropertySet, PValues as SiebelPropertySet)
GetMVGBusComp Method for a Business Component |
Returns the multivalue group business component that is associated a business component field. |
Dim busComp as SiebelBusComp Dim mVGBusComp as SiebelBusComp set mVGBusComp = busComp.GetMVGBusComp(FieldName as String)
GetNamedSearch Method for a Business Component |
Returns the name of a search specification. |
Dim busComp as SiebelBusComp Dim sValue as String sValue = busComp.GetNamedSearch(SearchName as String)
GetPicklistBusComp Method for a Business Component |
Returns the name of the pick business component that is associated with a field in the current business component. |
Dim busComp as SiebelBusComp Dim pickBusComp as SiebelBusComp Set pickBusComp = busComp.GetPicklistBusComp(FieldName as String)
GetSearchExpr Method for a Business Component |
Returns the current search expression that is defined for a business component. |
Dim busComp as SiebelBusComp Dim sExpr as String sExpr = busComp.GetSearchExpr
GetSearchSpec Method for a Business Component |
Returns the search specification that is defined for a business component. |
Dim busComp as SiebelBusComp Dim sSpec as String sSpec = busComp.GetSearchSpec(FieldName as String)
GetUserProperty Method for a Business Component |
Returns the value of a user property. |
Dim busComp as SiebelBusComp Dim sValue as String sValue = busComp.GetUserProperty(propertyName as String)
GetViewMode Method for a Business Component |
Returns the visibility mode for a business component. |
Dim busComp as SiebelBusComp Dim iMode as Integer iMode = busComp.GetViewMode
InvokeMethod Method for a Business Component |
Calls a method. |
Dim busComp as SiebelBusComp Dim sReturn as String sReturn = busComp.InvokeMethod( methodName as String, methArg1, methArg2, methArgN as String or StringArray)
LastRecord Method for a Business Component |
Moves the record pointer to the last record in a business component. |
Dim busComp as SiebelBusComp Dim bReturn as Boolean bReturn = busComp.LastRecord
Name Method for a Business Component |
Returns the name of a business component. |
Dim busComp as SiebelBusComp Dim sName as String sName = busComp.Name
NewRecord Method for a Business Component |
Adds a new record to a business component. |
Dim busComp as SiebelBusComp Dim bool as Boolean bool = busComp.NewRecord(whereIndicator as Integer)
NextRecord Method for a Business Component |
Moves the record pointer to the next record in a business component, making that record the current record. |
Dim busComp as SiebelBusComp Dim bReturn as Boolean bReturn = busComp.NextRecord
ParentBusComp Method for a Business Component |
Returns the name of a parent business component. |
Dim busComp as SiebelBusComp Dim parentBusComp as SiebelBusComp Set parentBusComp = busComp.ParentBusComp
Pick Method for a Business Component |
Places the currently chosen record in a pick business component into the appropriate fields of the parent business component. |
Dim busComp as SiebelBusComp busComp.Pick
PreviousRecord Method for a Business Component |
Moves the record pointer to the previous record in a business component, making that record the current record. |
Dim busComp as SiebelBusComp Dim bReturn as Boolean bReturn = busComp.PreviousRecord
RefineQuery Method for a Business Component |
Refines a query. |
Dim busComp as SiebelBusComp busComp.RefineQuery
SetFieldValue Method for a Business Component |
Sets a new value in a field for the current record of a business component. |
Dim busComp as SiebelBusComp busComp.SetFieldValue(FieldName as String, FieldValue as String)
SetFormattedFieldValue Method for a Business Component |
Sets a new value in a field in the current record of a business component. It accepts the field value in the current local format. |
Dim busComp as SiebelBusComp busComp.SetFormattedFieldValue(FieldName as String, FieldValue as String)
SetMultipleFieldValues Method for a Business Component |
Sets new values in the fields of the current record of a business component. |
Dim buscomp as SiebelBusComp buscomp.SetMultipleFieldValues(oPropSet as SiebelPropertySet)
SetNamedSearch Method for a Business Component |
Sets a named search specification on a business component. |
Dim busComp as SiebelBusComp busComp.SetNamedSearch(searchName as String, searchSpec as String)
SetSearchExpr Method for a Business Component |
Sets the search expression for a business component. |
Dim busComp as SiebelBusComp busComp.SetSearchExpr(searchSpec as String)
SetSearchSpec Method for a Business Component |
Sets the search specification for a business component. |
Dim busComp as SiebelBusComp busComp.SetSearchSpec(FieldName as String, searchSpec as String)
SetSortSpec Method for a Business Component |
Sets the sort specification for a business component. |
Dim busComp as SiebelBusComp busComp.SetSortSpec(sortSpec as String)
SetUserProperty Method for a Business Component |
Sets the value of a user property in a business component. |
Dim busComp as SiebelBusComp busComp.SetUserProperty(propertyName as String, newValue as String)
SetViewMode Method for a Business Component |
Sets the visibility type for a business component. |
Dim buscomp as SiebelBusComp buscomp.SetViewMode(mode As Integer)
UndoRecord Method for a Business Component |
Reverses any unsaved modifications made to the record. |
Dim busComp as SiebelBusComp busComp.UndoRecord
WriteRecord Method for a Business Component |
Saves to the Siebel database any modifications made to the current record. |
Dim busComp as SiebelBusComp busComp.WriteRecord
