Table 115. Summary of Web Applet Events for Siebel VB
WebApplet_InvokeMethod Event |
Called after Siebel CRM runs a specialized method on the Web applet. |
WebApplet_InvokeMethod(MethodName as String)
WebApplet_PreCanInvokeMethod Event |
Called before Siebel CRM calls the PreInvokeMethod event, allowing you to determine if the user possesses the authority to call the applet method. |
WebApplet_PreCanInvokeMethod (MethodName as String, CanInvoke as String)
WebApplet_PreInvokeMethod Event |
Called before Siebel CRM calls a specialized method for the Web applet or before it calls a custom method through oWebApplet.Invoke Method. |
WebApplet_PreInvokeMethod (MethodName as String) As Integer
WebApplet_Load Event |
Called immediately after Siebel CRM loads an applet. |
WebApplet_Load
WebApplet_ShowControl Event |
Allows a script to modify the HTML that the Siebel Web Engine creates when it renders a control on a Web page in a Siebel application that runs in standard interactivity mode. |
WebApplet_ShowControl (controlName as String, property as String, mode as String, HTML as String)
WebApplet_ShowListColumn Event |
Allows a script to modify the HTML that the Siebel Web Engine creates when it renders a list column on a Web page in a Siebel application that runs in standard interactivity mode. |
WebApplet_ShowListColumn (columnName as String, property as String, mode as String, HTML as String)
