Table 129. Summary of Business Component Methods for Siebel eScript
ActivateField Method for a Business Component |
Activates a field. |
var myBusComp; myBusComp.ActivateField(fieldName);
ActivateMultipleFields Method for a Business Component |
Activates multiple fields. |
var myBusComp; myBusComp.ActivateMultipleFields(oPropSet);
Associate Method for a Business Component |
Creates a new many-to-many relationship for the parent object through an association business component. |
var myBusComp; myBusComp.Associate(whereIndicator);
BusObject Method for a Business Component |
Returns the name of the business object that the business component references. |
var myBusComp; var busObject; busObject = myBusComp.BusObject();
ClearToQuery Method for a Business Component |
Clears the current query but does not clear sort specifications on a business component. |
var myBusComp; myBusComp.ClearToQuery();
DeactivateFields Method for a Business Component |
Deactivates the fields that are currently active from the SQL query statement of a business component. |
var myBusComp; myBusComp.DeactivateFields();
DeleteRecord Method for a Business Component |
Removes the current record from a business component. |
var myBusComp; myBusComp.DeleteRecord();
ExecuteQuery Method for a Business Component |
Returns a set of business component records. |
var myBusComp; myBusComp.ExecuteQuery(cursorMode);
ExecuteQuery2 Method for a Business Component |
Returns a set of business component records. Allows you to control the number of records Siebel CRM returns. |
var myBusComp; myBusComp.ExecuteQuery2(cursorMode, ignoreMaxCursorSize);
FirstRecord Method for a Business Component |
Moves the record pointer to the first record in a business component, making that record the current record. |
var myBusComp; var bIsRecord; bIsRecord = myBusComp.FirstRecord();
FirstSelected Method for a Business Component |
Makes the first record of the multiple selection in a business component active. |
var myBusComp; var bIsMultipleSelection; bIsMultipleSelection = myBusComp.FirstSelected();
GetAssocBusComp Method for a Business Component |
Returns the name of the association business component. |
var myBusComp; var AssocBusComp; AssocBusComp = myBusComp.GetAssocBusComp();
GetFieldValue Method for a Business Component |
Returns the value of a field from the current record of a business component. |
var myBusComp; var sValue; sValue = myBusComp.GetFieldValue(FieldName);
GetFormattedFieldValue Method for a Business Component |
Returns a field value that is in the same format that the Siebel client uses. |
var myBusComp; var sValue; sValue = myBusComp.GetFormattedFieldValue(FieldName);
GetMultipleFieldValues Method for a Business Component |
Returns a value for each field specified in a property set. |
var myBusComp; myBusComp.GetMultipleFieldValues (oFields, oValues );
GetMVGBusComp Method for a Business Component |
Returns the multivalue group business component that is associated a business component field. |
var myBusComp; var MvgBusComp; MvgBusComp= myBusComp.GetMVGBusComp(FieldName);
GetNamedSearch Method for a Business Component |
Returns the name of a search specification. |
var myBusComp; var sValue; sValue = myBusComp.GetNamedSearch(SearchName);
GetPicklistBusComp Method for a Business Component |
Returns the name of the pick business component that is associated with a field in the current business component. |
var myBusComp; var pickBusComp; pickBusComp = myBusComp.GetPicklistBusComp (FieldName);
GetSearchExpr Method for a Business Component |
Returns the current search expression that is defined for a business component. |
var myBusComp; var sExpr; sExpr = myBusComp.GetSearchExpr();
GetSearchSpec Method for a Business Component |
Returns the search specification that is defined for a business component. |
var myBusComp; var sSpec; sSpec = myBusComp.GetSearchSpec(FieldName);
GetSortSpec Method for a Business Component |
Returns the sort specification for a business component. |
var sSortSpec = this.GetSortSpec();
GetUserProperty Method for a Business Component |
Returns the value of a user property. |
var myBusComp; var sValue; sValue = myBusComp.GetUserProperty (propertyName);
GetViewMode Method for a Business Component |
Returns the visibility mode for a business component. |
var myBusComp; var iMode; iMode = myBusComp.GetViewMode();
InvokeMethod Method for a Business Component |
Calls a method. |
var myBusComp; var sReturn; sReturn = myBusComp.InvokeMethod(methodName, methodArg1, methodArg2,..., methodArgn);
LastRecord Method for a Business Component |
Moves the record pointer to the last record in a business component. |
var myBusComp; var iReturn; iReturn = myBusComp.LastRecord();
Name Method for a Business Component |
Returns the name of a business component. |
var myBusComp; var sName; sName = myBusComp.Name();
NewRecord Method for a Business Component |
Adds a new record to a business component. |
var myBusComp; myBusComp.NewRecord(whereIndicator);
NextRecord Method for a Business Component |
Moves the record pointer to the next record in a business component, making that record the current record. |
var myBusComp; var bFound; bFound = myBusComp.NextRecord();
NextSelected Method for a Business Component |
Makes the next record of the current multiple selection the active record. |
var myBusComp; var iReturn; iReturn = myBusComp.NextSelected();
ParentBusComp Method for a Business Component |
Returns the name of a parent business component. |
var myBusComp; var parentBusComp; parentBusComp = myBusComp.ParentBusComp();
Pick Method for a Business Component |
Places the currently chosen record in a pick business component into the appropriate fields of the parent business component. |
var myBusComp; myBusComp.Pick();
PreviousRecord Method for a Business Component |
Moves the record pointer to the previous record in a business component, making that record the current record. |
var myBusComp; var iReturn; iReturn = myBusComp.PreviousRecord();
RefineQuery Method for a Business Component |
Refines a query. |
var myBusComp; myBusComp.RefineQuery();
SetFieldValue Method for a Business Component |
Sets a new value in a field for the current record of a business component. |
var myBusComp; myBusComp.SetFieldValue(FieldName, FieldValue);
SetFormattedFieldValue Method for a Business Component |
Sets a new value in a field in the current record of a business component. It accepts the field value in the current local format. |
var myBusComp; myBusComp.SetFormattedFieldValue (FieldName, FieldValue);
SetMultipleFieldValues Method for a Business Component |
Sets new values in the fields of the current record of a business component. |
var myBusComp; myBusComp.SetMultipleFieldValues (oPropSet);
SetNamedSearch Method for a Business Component |
Sets a named search specification on a business component. |
var myBusComp; myBusComp.SetNamedSearch(searchName, searchSpec);
SetSearchExpr Method for a Business Component |
Sets a search expression for a business component. |
var myBusComp; myBusComp.SetSearchExpr(searchSpec);
SetSearchSpec Method for a Business Component |
Sets the search specification for a business component. |
var myBusComp; myBusComp.SetSearchSpec(FieldName, searchSpec);
SetSortSpec Method for a Business Component |
Sets the sort specification for a business component. |
var myBusComp; myBusComp.SetSortSpec(sortSpec);
SetUserProperty Method for a Business Component |
Sets the value of a user property in a business component. |
var myBusComp; myBusComp.SetUserProperty (propertyName, newValue);
SetViewMode Method for a Business Component |
Sets the visibility type for a business component. |
var myBusComp; myBusComp.SetViewMode(viewMode);
UndoRecord Method for a Business Component |
Reverses any unsaved modifications made to the record. |
var myBusComp; myBusComp.UndoRecord();
WriteRecord Method for a Business Component |
Saves to the Siebel database any modifications made to the current record. |
var myBusComp; myBusComp.WriteRecord();
