Table 146. Summary of Siebel HTML Application Methods for the Web Client Automation Server
GetLastErrCode Method for an Application |
Returns the error code for the error that Siebel CRM logged most recently. |
Dim siebelApp As SiebelHTMLApplication Dim iErr as Long iErr = siebelApp.GetLastErrCode
GetLastErrText Method for an Application |
Returns the text message for the error that Siebel CRM logged most recently. |
Dim siebelApp As SiebelHTMLApplication Dim sText as String sText = siebelApp.GetLastErrText
GetService Method for an Application |
Locates a business service. If this business service is not already running, then Siebel CRM starts it. |
Dim siebelApp As SiebelHTMLApplication Dim svc As SiebelService Set svc = siebelApp.GetService(ServiceName as String)
Name Method for an Application |
Returns the name of the Siebel application. |
Dim siebelApp As SiebelHTMLApplication Dim name as String name = siebelApp.Name
NewPropertySet Method for an Application |
Creates a new property set. |
Dim siebelApp As SiebelHTMLApplication Dim propSet as SiebelPropertySet Set propSet = siebelApp.NewPropertySet
