Siebel Order Management Guide > Integrating Order Management with Oracle ATG Web Commerce > Setup Tasks for Integrating Siebel Business Applications with Oracle ATG Web Commerce > Creating Separate Web Content Export Jobs for Each UserThe system preference, SiebCommIntOpenJobSearchSpec, determines which export job header the export job detail records are added to. The system preference applies to the business component ISS Web Commerce Export Contents - Header. The default value is as follows: This setting means that the detail records are added to the header record that is open. If you want each user to have an export job header of his or her own, with only the details that the user creates, then you can change this search specification and filter the search by user. |
Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
