Siebel Order Management Guide > Integrating Order Management with Oracle ATG Web Commerce > Setup Tasks for Integrating Siebel Business Applications with Oracle ATG Web CommerceYou must install Siebel Commerce Object Aggregator. In addition, you can use a number of system preferences to set up the integration of Siebel Business Applications with Oracle ATG Web Commerce. These setup tasks are not required. The Siebel application exports records to Oracle ATG Web Commerce if you do not change the default values of these system preferences. However, you might have to change these system preferences to make the Siebel application behave in the way that you want. These installation and setup tasks are described in the following topics: |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
