Siebel Order Management Guide > Integrating Order Management with Oracle ATG Web Commerce > Process of Exporting Records to Oracle ATG Web Commerce > Creating a Web Content Export Job Detail for Siebel Products or PromotionsYou may include any type of product in an export job, without limitation based on data value. Because Siebel Business applications treat promotions as a type of product, you can export promotions in the same way that you export products. The following best practices are recommended:
You can create an export job by using the Update Commerce App button or menu option on the following views of the Administration - Product screen:
The following procedure uses the Products list as an example, but you can also perform the same task in the other views. To create a Web content export job detail for Siebel products
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
