Siebel Order Management Guide > Integrating Order Management with Oracle ATG Web Commerce > Process of Exporting Records to Oracle ATG Web Commerce > Creating a Web Content Export Job Detail for Siebel CatalogsTo export nested Siebel categories correctly, you must set the system preference SiebCommExpCtlgCtgyHier to Y. This setting turns on the functionality that exports all children of a given level within the catalog hierarchy as well as all parents. For more information, see Enabling Cascading Deletions of Web Content Export Job Details. Only catalogs of the type Buying can be exported to Oracle ATG Web Commerce. If an export job includes catalogs of other types, then SCOA does not create XML files for these nonbuying catalogs, so they are not exported to ATG Web Commerce. The following best practices are recommended for exporting catalogs:
You can create an export job by using the Update Commerce App button or menu option on the following views of the Administration - Catalog screen:
The following procedure uses the Catalogs view as an example, but you can also perform the same task in the other views. NOTE: Adding a catalog to a job does not automatically add the Product records of the catalog to the job. An administrator must manually add the products of the catalog to the job. To create a Web content export job detail for Siebel catalogs
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
