Siebel Order Management Guide > Product Data Service and Import Export API Reference > ISS Authoring Import Export Business Service Reference > ExportFullVOD MethodSimilar to the ExportVOD Method. In addition, for ISS_PROD_DEF and ISS_CLASS_DEF structures, for each root object, runs a recursive algorithm to collect a list of dependencies, a set of self-contained objects. This set includes: parent class definition, attribute definitions used to create local attributes; relationship base class definition; product definitions referred in relationship domain as sub-products. Resulting combined list of objects is used as a set of objects to be exported in a same way as in ExportVOD. SyntaxISS Import Export Authoring Service.InvokeMethod("ExportFullVOD", Input Arguments,Output Arguments); ArgumentsProperties of Input Arguments: combination 1 If this combination of values is passed to the method, then it considers each entry in the content of the JWS project as a Root object. The resulting combined property set will include all of them. Properties of Input Arguments: combination 2
If this combination of values is passed to the method, then it considers a single entry as a Root object. The resulting property set includes only this object (as a child property set). Elements and their Properties in Output Arguments: The output argument property set is a wrapper around multiple elements. The type of the first element is TableOfContent, and it contains a summary of exported VOD structures. Child elements are typed according to VOD Types of each exported Object and represent a short description.
Error ConditionsMight return generic error codes from Object Manager, From EAI or from service. These codes are mainly about input format, for example, that a parameter is missing parameter. |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
