Siebel Order Management Guide > Product Data Service and Import Export API Reference > ISS Authoring Import Export Business Service ReferenceThe main purpose of this business service is to let you move versioned object definitions (VODs) between databases. It supports the following VODs:
In addition, this business service allows you to fix S_PROD_INT records created with the EIM process so they are usable by the ISS framework. In the case of versioned objects, it creates the minimum set of necessary records that is needed. NOTE: You can import simple products using EIM and run a process to generate a default workspace. However, you cannot use EIM to import customizable objects, which you must import using ISS Authoring Import Export Service. Modeling Data Before Using ISS Import Export Authoring ServiceTo be able to use the standard approach successfully, users must take some precautions during modeling. VODs manually created on two databases are be treated as different objects even if their VOD Names match. CAUTION: Therefore, you must never create 2 master copies of the same VOD manually on two different DBs. Instead move existing definitions from one DB to another through Import/Export, or ADM. After import, you can freely modify replicated objects in any database and move them around. Observe the following guidelines to make objects compatible when multiple development environments are required:
Methods of the ISS Import Export Authoring Service |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
