Siebel Order Management Guide > Product Data Service and Import Export API Reference > ISS Authoring Import Export Business Service Reference > Post_EIM_Upgrade MethodThis method locates all records in S_PROD_INT with missing or broken association with the S_VOD record and creates the necessary supporting structure for versioning. Depending on the input property set parameters, the method can operate in two different modes: standard or staging mode. For each identified entry in S_PROD_INT, it does the following:
In Staging mode, it continues by doing the following: In Standard behavior mode, it continues by doing the following:
In both modes, if you set the property ReportOnly = TRUE, then the upgrade does not occur and the method only generates a report of orphan records. In this case, the output property set's property Warning contains a report of errors or list of orphans. NOTE: In both modes, if you set the property ReportOnly = TRUE, then the upgrade does not occur and the method only generates a report of orphan records. In this case, the output property set's property Warning contains a report of errors or list of orphans. SyntaxISS Import Export Authoring Service.InvokeMethod("Post_EIM_Upgrade", Input Arguments,Output Arguments); ArgumentsProperties of Input Arguments (standard mode) Properties of Input Arguments (staging mode) Properties of Output Arguments ExampleAfter using EIM to import data into S_PROD_INT, you must execute the method Post_EIM_Upgrade with the Input Argument ReportOnly = False to release the products. If ReportOnly = TRUE, then no changes are made to the database. There are two modes for using this method:
After EIM imports, you can use the business service simulator to execute with ReportOnly = FALSE to release the imported products. Execute using the business service simulator as follows: |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
