Siebel Order Management Guide > Workflow and Method Reference for Order Management Interface > Order Management Interface Workflow Reference >
ISS Post Approval Workflow (Agreement) Workflow
ISS Post Approval Workflow (Agreement) workflow, shown in Figure 31, checks whether any additional approvals are needed. It is triggered when a user approves an Agreement to see if additional approvals are needed.
Figure 31. ISS Post Approval Workflow (Agreement) Workflow
Workflow Description. This workflow does the following: Calls the SetApprovalDecision method of the ISS Approval Bus Service Business Service. This will set the status of the current approval item and check to see if additional approval is needed. Process Properties
ActionLIC |
Service Agreement |
String |
The Language Independent Code for the Action Field |
Approval Level Name |
Service Agreement |
String |
The name of the Approval Level that is defined in the Approval Administration screen. |
Error Code |
Service Agreement |
String |
The Error Code that is returned if an error occurs. |
Error Message |
Service Agreement |
String |
The Error Message that is returned if an error occurs. |
InboxItemId |
Service Agreement |
String |
The Row ID of the current Universal Inbox Item. |
InboxTypeName |
Service Agreement |
String |
The Universal Inbox Type. |
Object Id |
Service Agreement |
String |
Obsolete. |
ObjectId |
Service Agreement |
String |
The Row ID of the current object. |
OwnerInfoId |
Service Agreement |
String |
The Row ID of the approver. |
Process Instance Id |
Service Agreement |
String |
The Row ID of the current workflow process. |
Returned Status |
Service Agreement |
String |
The Status of the Approval Item. |
SendEmail |
Service Agreement |
String |
Variable to determine if email is sent to the person who needs to approve the current item. |
SeqNum |
Service Agreement |
String |
The Sequence Number for the current approval level. |
Siebel Operation Object Id |
Service Agreement |
String |
The Row ID of the Siebel Operation Object. |
StageId |
Service Agreement |
String |
The Row ID of the current Approval Stage. |
